Fluid Replacement
Old Jul 27, 2011 | 01:46 AM
Crex39's Avatar
Crex39
Originally Posted by NoCoLoco
Lots of Amsoil haters out there and as far as I'm concerned they are all talking out their ***! I've always had excellent results with Amsoil 20/50 in the motor. Combined with a HD oil filter and changed every 5000 miles it has always done everything I've asked of it and there are times when I ask a lot. My bike's normal operating temperature is about 230° and it has hit 300° more times than I care to remember and it has never been "black as tar" and/or "thin as water". When I drain it, it has never sparkled with metallic debris and there is very little shavings on the magnetic drain plug, if any. You guys can talk all the **** you want but Amsoil has made a believer out of me and has EARNED the right to be used in my bike.
I Don't have any scientific data, but I was stuck on a freeway closed down for a fatal accident and spent 45 minutes going a half mile to the exit. The outside temp was 75, night time. After 40 minutes running Amsoil with app. 700 miles on it I lost my pressure (down to 15 psi) and some bad noises started coming from the engine. After I was able to get off the highway and take the back roads, pressure worked back up to 30 psi. The next day I changed the oil and it looked like something Rosanne Barr would expell after free taco night. very thin, runny, bubbles and very dark. I replaced with Mobil 1. While Mobil 1 may have had the same results, it is about $4 a quart cheaper. I used to be a believer in Amsoil, ran it through my Superglide religiously, along with my wife's sporty. I don't think Amsoil is that bad, but I definitely see its not that special. Definitely not worth the price.
Old Jul 27, 2011 | 06:25 AM
troop's Avatar
troop
Originally Posted by Harleyboyddk
The op selected a transmission grade lube, that's the important thing. Change regularly with your personal favorite, keep 20/50 motor oil out of the transmission and you're good.
Kind of ironic as both Amsoil and M1 recommend their 20w-50 motor oils in the transmission over their 75w-90/110 gear lubes. Whys that?
Old Jul 27, 2011 | 07:20 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Hi all,
After a few weeks running MOTUL 20W50 mineral oil in the primary transmission (meets HD spec.) and 75W80 in the gearbox, shifting is very accurate and the clutch is progressive but firm as it engages.
My only observation is that after a few days without using the bike, the clutch plates stick together as they did back in the 70's. It takes me 15 seconds to shake the bike back and forth to release the clutch but I guess that's the price to pay
Old Jul 27, 2011 | 08:49 AM
sargek's Avatar
sargek
Originally Posted by mrfikser
its your money to throw away as you like....there are only really 3 types of oil..dino, synthetic and a mix of the two....under normal conditions (which all but the most highly modified harleys run) they all do a more than adequate job....none of them break down, run out of detergents or insufficiently lubricate under the conditons which a harley is used ....the higher grade oils are really only needed in extreme racing conditions ( I am talking about supercharging, track racing and the like)......they will all last for the 5000 miles or so between oil changes on a street bike...Oh, and those hot summer days when you are stuck in traffic for an hour doesn't count as "extreme", its just normal motorcycle use...
Now that's the best oil post I have heard yet, seriously - something realistic!
Old Jul 27, 2011 | 01:58 PM
NoCoLoco's Avatar
NoCoLoco
I disagree. These Twin Cams work hard and run hot and I can't think of a better application for synthetic oil givin its tolerance to heat versus dino. In "ideal" conditions you'd be right but oil temps in excess of 300° is far from "ideal" and can really wear an oil out. JMO, to each his own.
Old Jul 27, 2011 | 02:11 PM
LarryLives's Avatar
LarryLives
I use amsoil and love it!
Just dont use corn oil, olive oil, or oil of olay.
Old Jul 27, 2011 | 03:18 PM
eng23ine's Avatar
eng23ine
I use Mobil 1 simply for that fact that if im out on the road and need a quart I can pull into the autozone or walmart and get it.......Cant do that with amsoil.
Old Jul 27, 2011 | 05:32 PM
BackRoader's Avatar
BackRoader
Redline shockproof in the tranny, Redline primary oil in the primary and Mobil 1 in the engine for me.
Old Jul 29, 2011 | 08:31 AM
RKC2010's Avatar
RKC2010
Pulled the following statement from another thread on here:
In the past year or so HD, as well as several oil manufacturers, have started recommending the use of their 20w-50 synthetic engine oil in more than just the engine. You can use it in the primary to lube the chain, and in the transmission, where it must operate in a gear-grindin' environment. So, how can HD say to use 20w-50 stuff where they once called for 75w-90 stuff? Wouldn't it be too thin to do the job?
Here's the answer: Viscosity is measured by different scales for engine oil and gear oil. The two systems aren't directly comparable, number-for-number. Here's a reasonably accurate comparison between the two systems. Please remember that I said "reasonably accurate", as there is some overlap.
SAE Engine Oil SAE Gear Oil
10w thru mid range of 20w = 75w
Mid 20w thru mid 30w = 80w
Mid 30w thru low 40w = 85w
Low 40w thru 50w = 90w
60w up = 140w
Old Jul 29, 2011 | 08:59 AM
mgmmgm's Avatar
mgmmgm
I have used Amsoil, and M1 20-50. Right now I got Castrol 20-50 v-twin non synthetic in the engine, and it will do for my road trip this next week. I feel Ams, and M1 are both are pretty good. I have 1,400 miles on the bike at present. So, I got M1 20-50 on the shelf for oil change when I get back from my road trip next week.
Changing the engine oil, I do that more frequently than 5K, never usually even get to 3K before I change the oil. It's just me. I changed my oil on my flstf before 3K always, and used the scavenger oil change. ( peace of mind ) - see the web site below.
Will be doing a scavenge oil change on my RKC, so all of the oil gets changed as well. Even when you do a standard oil change the 28-30 oz of dirty oil remains in the sump. See web site below for more info.
http://www.roguechopper.com/about.htm
