I got the jack... anyone done this?
Old Jul 30, 2011 | 05:25 PM
Baxley Trailers and Chocks's Avatar
Former Sponsor
We are a new sponsor to the forum:
If you are willing to spend some more money, this is the way to go.... You can feel 100% confident that your bike will NEVER fall.... The 2 piece cradle clamps your front wheel as you roll on.
Plus, bolt it to a trailer and you can load your bike by yourself and only use 2 straps on the rear (pulling the bike forward)....
30 seconds to load and unload your bike. Here is a video. http://www.youtube.com/watch?v=lxW_wJE3vFk
www.baxleycompanies.com
Old Jul 31, 2011 | 07:47 AM
Gitarded's Avatar
Gitarded
Originally Posted by soft 02
Air over hyd pump is around 150.00 through ESCO. Not bad and the pump is a foot valve.
What is ESCO? Do you have a link? HF has them for $139 without the coupons that are all over the place. I just need to figure out how to hook it up. I may be able to connect to the fitting where the cylinder pump push rod goes.
Old Aug 1, 2011 | 12:20 PM
Gitarded's Avatar
Gitarded
This is the wheel chock from Harbor Freight, Coupon had it for $39 bucks. Seems well made. I mounted it right to the lift table.
Old Aug 1, 2011 | 03:22 PM
soft 02's Avatar
soft 02
I dont know how to post a link but google: ESCO tire service and search: hyd pump. Its an industrial air over hyd pump we use for porta power jacks and heavy equipment tire bead breakers. Ill post a pic when I get home.
Old Aug 1, 2011 | 04:18 PM
TNCarters's Avatar
TNCarters
Air will require a larger cylinder than hydraulic to apply the needed force. I doubt you have the air pressure available that the hydraulic pump is applying to the stock cylinder. It may be several hundred psi hydraulic pressure.
Old Aug 1, 2011 | 09:04 PM
Gitarded's Avatar
Gitarded
I was thinking about hooking one of these babys to it.
http://www.harborfreight.com/catalog...hydraulic+pump
Not sure if it would allow it to retract too. Looking for some experience with them.
Old Aug 1, 2011 | 09:35 PM
soft 02's Avatar
soft 02
Yep. Same idea but yes it is one way pressure but bleeds off the other way. That unit is probably fine for a lift. ESCO ones are industrial duty.
Old Aug 1, 2011 | 09:38 PM
not2kool's Avatar
not2kool
I have a HF lift that is both hydraulic and air operated. Do they not sell this one any more? When my pump started leaking I ordered a new hyd/air pump from HF to replace the old one. If they still sell it you could order the pump from them.
Old Aug 2, 2011 | 07:47 AM
Gitarded's Avatar
Gitarded
Thanks guys
N2K do you know the P/N of the one they ordered for you?
Soft 02, does ESCO have a website. Maybe an industrial version would be better choice for a few bucks more.
Old Aug 2, 2011 | 09:24 AM
soft 02's Avatar
soft 02
Thanks guys
this is the pump I have.http://www.esco.net/tire-changing-eq...8&cat=3&page=1
