I got the jack... anyone done this?
Old Jul 29, 2011 | 10:51 PM
Gitarded's Avatar
Gitarded
Default I got the jack... anyone done this?
I bought a Harbor Frieght lift table, hydraulic. I wanted the air over but they don't have it anymore. Has anybody out there converted one of these jacks over to air over hydraulic? Anyone know if it is possible? The table seems to be well made, at least for the $299 it cost me. I also picked up the HF version of the condor chock that was $39.
As always, appreciate the input
Thanks
Old Jul 30, 2011 | 12:38 AM
crackercap's Avatar
crackercap
I have had the setup you mention for some time, and I too would prefer air to lifting the table rather than standing there pumping. I am sure it can be done but don't have the smarts to figure it out..
Old Jul 30, 2011 | 01:06 AM
soft 02's Avatar
soft 02
Pretty simple. Hook an air line to the up hyd fitting at the base of the cyl. Put a brass mesh plug at the top hyd hoes fitting.
Old Jul 30, 2011 | 02:09 AM
roadgliderick's Avatar
roadgliderick
this is mine kinda hard to see but the brand is direct lift some guy bought it used 2 times i got it for $300.00. and it comes with the side plates wheel chalk and it is hydrolic. thats a friend of mine working on his road king
Old Jul 30, 2011 | 02:12 AM
roadgliderick
easier said then done.
Old Jul 30, 2011 | 02:21 AM
soft 02's Avatar
soft 02
Why? Give me specifics and we can come to a solution.
Old Jul 30, 2011 | 02:46 AM
Bob-n-Ohio's Avatar
Bob-n-Ohio
I really need a good, safe bike lift. Tired of my Sears jack.....
Old Jul 30, 2011 | 03:39 AM
mike5511's Avatar
mike5511
Here we go.......jack wars!......
Old Jul 30, 2011 | 03:49 AM
Bob-n-Ohio's Avatar
Bob-n-Ohio
No jack war from me. I just need one that lifts higher so I can work on my bike easier. Back bothers me too much bent over with my current jack.
Old Jul 30, 2011 | 06:35 AM
HalfFast's Avatar
HalfFast
Hydraulic or Pneumatic, the jack doesn't know. It will work the same with air as it will with oil. You need to vent the top of the piston to allow the air an escape route and you can put a tee with a drain valve in the inlet hose to the jack. The valve off of the tee will allow you to drain the air out of the bottom of the cylinder to lower your jack. How hard is that?
