seat bolt snapped
Old Jul 30, 2011 | 03:59 PM
luc.who's Avatar
luc.who
Default seat bolt snapped
So I am in the garage cleaning the bike and I take of the sundowner to put my stock seat on for a solo long ride, I hear ping ping, WTF? Out of the fender falls the nut for the rear seat. Snapped....oh well guess its better than being on the bike when that happened. I think I will pick up two of tommorow. Seems like something that may be an issue swapping the seat as often as I do.
Old Jul 30, 2011 | 04:11 PM
aviator's Avatar
aviator
never heard of someone breaking the seat bolt... you must be stronger than you imagined.
Old Jul 30, 2011 | 04:39 PM
mkguitar's Avatar
mkguitar
put a little lube on the threads of the new nut, and don't overtighten the seat machine screw- just kinda finger tight +
probably over torqued and stretched the clips.
if fishing in the new one- a bass guitar string might be helpful, for those who have them lying around.
Mike
Old Jul 30, 2011 | 09:14 PM
dbell66253's Avatar
dbell66253
That nut has a ring that holds it in, its a PIA to get to with the wheel in place, don't ask me how I know, lol.
Old Jul 31, 2011 | 06:00 AM
luc.who's Avatar
luc.who
I was afraid of that, I was hoping I run out this morning, get 2 of them and be riding by noon. DA*IT.
Old Jul 31, 2011 | 10:01 AM
FlamedFXR's Avatar
FlamedFXR
Theres a trick to replacing it, something about using a string. Do a search for it.
Old Jul 31, 2011 | 10:06 AM
gmc's Avatar
gmc
Tape the nut to a coat hanger (straightened with a little bend on end) or a piece of heavy wire and slide it up under the fender. It helps to have someone with a magnet to guide it thru.
Old Jul 31, 2011 | 10:08 AM
dawg's Avatar
dawg
You are running the seat bumper kit that was covered in a bulletin for the 09 and 10 FLHX and FLTRX's on the Sundowner, yes?
Old Jul 31, 2011 | 02:13 PM
luc.who's Avatar
luc.who
Dawg, I am not. I am going to look into that this week. As I was searching for how to fix this I saw your post on the bumper kit. Thanks
BTW, i found and easy way to replace the nut. I use 3 zip ties. 1 goes through the nut, 2 other zip ties attached together and I feed the two down towards the tire, I then reach in, grab the 2 zip ties, attach the 3rd one and pull up through the hole in the fender. Then put the u clamp on the nut. Took me about 15 minutes.
jeffscra
Apr 25, 2016 10:37 AM
rocstar50
General Topics/Tech Tips
Feb 9, 2012 02:50 PM
hellfrozeover
Aug 22, 2011 03:50 PM
m1crazy
Jun 1, 2011 07:30 AM
USMCNewdog
Apr 18, 2011 07:03 PM
