Biketronic Amp ??
Old Aug 2, 2011 | 07:43 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Default Biketronic Amp ??
For anyone who is running the Biketronic Titan Amp, is it 100% plug n play with the stock HD HK radio???
Yeah, I know I can find a cheaper amp but I'm looking at the compact size and if it is, 100% plug n play with my HK radio (that is currently in route to Iron Cross Audio).
Old Aug 2, 2011 | 09:07 AM
dnitram's Avatar
dnitram
A "Bump" for you.
Old Aug 2, 2011 | 09:17 AM
FLHTCU Owner's Avatar
FLHTCU Owner
Is it 100% P&P? No. The power supply has to come from the battery, and it also uses the cigarette lighter for powering it on.
Old Aug 2, 2011 | 09:22 AM
HDV-GLIDE's Avatar
HDV-GLIDE
That's a no brainer then.......Suppose I could also use the spare connector (blu/blk) that's attached to the headlight wiring for power also...
Old Aug 2, 2011 | 09:30 AM
FLHTCU Owner
Possibly. I didn't want to jack with doing that, so I bit the bullet and ran it to the battery.
I can send you the installation instructions if you want to view them.
Old Aug 2, 2011 | 02:29 PM
HDV-GLIDE's Avatar
HDV-GLIDE
I already have a hot wire and a ground wire in the fairing running directly to the battery. I also spliced in a connector to the blue wire coming off of the headlight harness for another ignition on hot wire.
I ordered the Biketronic amp & speakers from Eastern Performance.....If anyone is interested in this set up, call them....Their price will blow you away....
Wondering if I can still use my Hog Tunes Tweeter Pod, hope so....
BigWaterJim
Audio Systems
Aug 14, 2016 09:58 AM
Cornutjim
Audio Systems
May 10, 2016 05:01 AM
speedracerx0509
Audio Systems
15
Sep 27, 2013 12:15 PM
sh4325
Jun 25, 2011 11:11 PM
n8dc
May 10, 2009 10:46 AM
