Jugs when they are a turn off
Old Aug 2, 2011 | 07:32 PM
Gitarded's Avatar
Gitarded
Default Jugs when they are a turn off
Does anyone know what year MoCo cut in the code change to shut off the rear cylinder to keep the heat down? A friend of mine said 11 and only with the 103. I thought it was 10 and only the 103.
Thanks
Old Aug 2, 2011 | 07:36 PM
luc.who's Avatar
luc.who
In 08 my road king had this.
Old Aug 2, 2011 | 07:37 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
in late 07,or early 08,they came out with a download for 07 it was automatic for 08 it had to enabled in the ecm then u could turn it on and off,09 it was there from the factory.
Dionicio's Avatar
Dionicio
I think ( pretty sure) the feature came out in 08. My o8 UC has it.
dnitram's Avatar
dnitram
My 2009 Street Glide had it.
Old Aug 2, 2011 | 07:39 PM
Ron750's Avatar
Ron750
I heard mid 08, on 96.
Old Aug 2, 2011 | 07:46 PM
bigdumbnoitall00
mid year 08 ,07 and early 08 it was available as a ecm flash,on the 96
Old Aug 2, 2011 | 07:47 PM
Gitarded's Avatar
Gitarded
Wow wonder if my 08 Fatboy has it. Is there a way to tell without using a timing light?
Old Aug 2, 2011 | 07:53 PM
Dionicio's Avatar
Dionicio
You should ask Your dealer. The ECM flash is or was free.
Old Aug 2, 2011 | 08:01 PM
pargenz's Avatar
pargenz
Thanks
The Engine Idle Temperature Management System (EITMS) is available on Touring scoots from 2007 to the present lineup. It does require a reflash of the ECM on all 2007 and 2008 models. Those models produced after December 3, 2007 already have EITMS installed and ready for you to activate using a simple throttle activated switch.
When you are stopped and at idle, simply push the throttle forward (closed) to roll off position and hold. After approximately 3 seconds, the cruise control indicator will flash either red (disabled) or green (enabled). Repeat the procedure to toggle between the two.
During hot idle, or when the motorcycle is off-throttle and running at hot temperatures, EITMS shuts off fuel to the engine's rear cylinder, leaving it to idle on the front cylinder only. Without combustion, the rear cylinder and exhaust header will begin to cool, bringing relief to the rider (and passenger) soon after. Once the rear cylinder cools to a predetermined temperature, or as soon as the rider accelerates, both cylinders resume operation. And by maintaining constant rpm during rear cylinder shutdown, transitions between one and two cylinder operation are nearly seamless.
EITMS is purely for rider comfort. When it activates and shuts off the rear cylinder, it's not because the motor is overheating. It's designed to reduce the heat radiating from the rear cylinder to the rider.
Once an appointment is made, the EITMS software reflash can be performed for free by any H-D dealer, usually while you wait. If, for any reason, the rider does not like the EITMS, it can be returned to the previous mapping for free.
