Big Bore Kit
Old Aug 3, 2011 | 06:16 AM
Challenger's Avatar
Challenger
Default Big Bore Kit
My Electra has a 95" big bore kit installed. Previous owner confirmed it and dealer service mgr confirmed it also.
Now can any of you tell me whats involved in this "kit"?? I feel dumb for asking but I'm trying to educate myself!
A little about the bike.. It has screaming eagle badging on the air cleaner and timing cover.
It has Rinehart pipes and unlike stock bikes I've seen, the exhaust comes off the fron cylinder and runs down the right side... off the rear cylinder the pipe goes down the left side...They dont run down the right side of the bike and one crosses over just ahead of the tire.
So I'm guessing it has a fuel remap and different air cleaner? Are the pipes actually headers? Would this kit also include HYD tensioners?
Old Aug 3, 2011 | 06:45 AM
dawg's Avatar
dawg
Sounds like it has Rinehart true duals which are actually headers. The big bore kit contains larger bore cylinders and slightly larger pistons. You have a stage 1 air cleaner and either a dealer download or a fuel management system like a SERT or PCIII. I doubt it has the hydraulic tensioners depending on when it was done.
Old Aug 3, 2011 | 07:38 AM
Challenger's Avatar
Challenger
Thanks! It was done a little over a year ago from what i've been told
Old Aug 3, 2011 | 08:09 AM
grbrown's Avatar
grbrown
It might be worth asking more questions! The 95" kit may have been done as part of a wider upgrade, including changing the cam tensioner plate. Installing the new jugs involved taking the heads off, pushrods etc, which would have made fitting an SE hydraulic tensioner easy, in fact a very sensible 2-in-1 upgrade!
Old Aug 3, 2011 | 08:27 AM
Challenger's Avatar
Challenger
Exactly what I was thinking! I asked the previous owner and all he told me was "they did the top end last spring"
Talking to the service mgr and I was told "it has a 95"kit" When asked about the cam tensioners I was told "no"??
Old Aug 3, 2011 | 09:40 AM
djl's Avatar
djl
Big bore kit involves increasing the bore from 3.750" to 3.875" which increases total displacement from 88" to 95". There is a Stage I and Stage II big bore upgrade; Stage I is cylinders and pistons only; Stage II includes SE203 cams and SE clutch spring.
You can put badges on a tricycle.
As someone has pointed out, the exhaust system is a set of Rinehart True Duals. Headpipes are stepped headers; true dual just means that the exhausr from the front and rear cylinders is not combined.
A fuel management system would have been a sensible part of the upgrade but not everyone does that. Some go with the dealer "flash" to the ECM, some go with "pot" type systems that add fuel like re-jetting a carburetor. A more sophisticated fuel management system like the SERT, TTS, SEST, PC would not necessarily be required for just an increase in displacement. If cams were installed as part of the upgrade, it would have made sense to installe a more sophisticated fuel management system and have the new configuraiton dyno tuned. This is worth more investigation and you should be asking the seller. If a system like the SERT, TTS, etc. was installed you should have received software and cables. If one of the DynoJet PC system is installed, it will be under the seat and clearly visible. If the motor had been dyno tuned, I would have expected the seller to provide a dyno sheet as well.
No but this would be a good upgrade and easy enough to check; just pull the cam cover. You shoud do that anyway and check the cam chain tensioners for wear.
kmille
Apr 27, 2014 09:12 PM
rebbe18
Apr 16, 2013 10:47 AM
RoadKingGibson
Exhaust System Topics
25
Nov 18, 2011 09:20 AM
DDC1225
Jul 14, 2006 08:04 PM
dragonzgod
Nov 8, 2005 01:05 AM
