Torque Wrench
Old Aug 3, 2011 | 05:05 PM
nivensid's Avatar
nivensid
Default Torque Wrench
Tried a search, not any luck. On my previous bike, I did most all my mechanical but never had a good torque wrench. Well now, with my new Ultra Limited, I want to do it right.
What torque wrench does everyone use on their Harley for general maintenance? It looks like 2 will be necessary. One for inch pounds and one for foot pounds. I have looked on line but figure I would go straight to the ones who actually use them on their bikes.
Thanks
Old Aug 3, 2011 | 05:12 PM
mkguitar's Avatar
mkguitar
Just go to Sears and get a good Craftsman.
Look at your manual, have a look at the range that you needs to cover.
get a "click" type, rather than a "beam" which uses a needle indicator.
The click type has springs inside which can stretch if left tensioned, so always return it to "0" after use.
Tempting though it is, do not buy used, as 1 hard drop and they need recalibrating.
Due to my many machines and activities I have 5 torque wrenches in various ranges, incl. a 1/4" inch pound.
the range I use most is probably 15 to 50 foot pounds, 3/8" drive.
Using extensions will change your readings, the wrench will likely have a chart to help you with that.
The big 150 foot pound stuff, I just use a 1 foot breaker bar and get my 150 pound wife to stand on it....
Most of the inch pound stuff is not crucial
and sometimes you can use a foot pound wrench : 12 inch pounds = 1 foot pound.
mike
Old Aug 3, 2011 | 05:27 PM
Chasenfish's Avatar
Chasenfish
Default +1
Another Craftsman user here.
Old Aug 3, 2011 | 05:36 PM
hog95023's Avatar
hog95023
I use a snap on digital has nm inch and foot pounds.
Old Aug 3, 2011 | 05:41 PM
69cj's Avatar
69cj
Wish I had access to the chart I found a while back but as an example if you'r using a 6 inch extension and torquing a true 90 degrees there is no change in the torque. 50 psi is still 50 psi.
Old Aug 3, 2011 | 05:52 PM
TORQUEY's Avatar
TORQUEY
Here you go...
1/2" Drive Click Stop Torque Wrench
Item # 239 Manufacturer: Pittsburgh
Torque wrench provides a range from 20 to 150 ft. lbs
Only: $32.99
Sale: $24.99
Qty:
Availability: In stock
Leaves the warehouse in 1-2 business days.
Shipping
View Shipping Rates
Economy Ground & Express Shipping available.
(Exclusions may apply)
Customer Rating:
Read 15 Reviews
Pittsburgh 3/8" Drive Click Stop Torque Wrench
1/4" Drive Click Stop Torque Wrench
(inch pounds: $19.95)
Old Aug 3, 2011 | 06:28 PM
SIDECAR BOB's Avatar
SIDECAR BOB
Originally Posted by TORQUEY
Here you go...
Only: $32.99
Sale: $24.99
Qty:
Shipping
View Shipping Rates
Customer Rating:
Read 15 Reviews
I have hear good things about the harbor freight torque wrenches and their accuracy is supposed to be very comprable to the craftsman wrenches.
Old Aug 3, 2011 | 06:33 PM
dusty6700's Avatar
dusty6700
Do NOT buy a cheap torque wrench! I use snap-on because I have them in my tool box....I'd recommend craftsman or any "name brand" for accuacy reasons! Especially if you're gonna do any work on the engine....spend the $$$ to get some quality torque wrenches! You'll be surprised how often you need them....once they're in your toolbox.
Old Aug 3, 2011 | 06:57 PM
bagman1's Avatar
bagman1
Old Aug 3, 2011 | 06:58 PM
wulffe's Avatar
wulffe
I would recommend Harbor Freight. If I was using them daily I might go with the more expensive tools but I use them infrequently. I'm sure I found a way to use the extra bucks.
