Do NOT buy a cheap torque wrench! I use snap-on because I have them in my tool box....I'd recommend craftsman or any "name brand" for accuacy reasons! Especially if you're gonna do any work on the engine....spend the $$$ to get some quality torque wrenches! You'll be surprised how often you need them....once they're in your toolbox.
Listen to this advice! Sooo true. I have owned Craftsman twice and they both failed on me. I was also forced to use a POS from Harbor Freight once when mine broke...ummm, crap. Cheap, yeah...but c'mon. Don't waste your money (and time).
Here's a review form WebBikeWorld. Scroll to the bottom and they talk about the Precision Instrument Torque Wrench. Great mid-priced tool that you'll have forever. http://www.webbikeworld.com/r3/torque-wrench/
If you have a 3/8 inch socket set (most are) get the same size torque wrench. The other thing to pay attention to is range. Most bolts you find on a bike will be in the lower ft/lb range or higher in/lb range. You can convert from ft/lbs to in/lbs by dividing by 12.
I would never use a $30 click type torque wrench on critical areas like oil & transmission bolts. Maybe axle bolts, but not much else. Buy yourself a quality, calibrated torque wrench. Below is the torque wrench I use. It's a Precision Instruments that goes from 0-50 Ft. Lbs/ 0-70 nm. That range covers just about everything you'll need to torque down, outside of the heavy duty bolts. Less than $200
Craftsman quality has gone down in the last few years. Their wrenches, combination, sockets, etc. are top notch, but stuff with moving parts just are not what they used to be. I won't waste any more money on sears drills and such and not the torque wrenches either. Go on line, read some of the user comments about the torque wrenches and then decide. Since I don't "wrench" for a living, the HF or Northern tool will work for me. And as said earlier, a beam type, mine is Craftsman, doesn't need calibration. As long as you don't drive over it and bend it, it will work just fine. It does take a bit more care in it's use to get accurate torque setting, but just take your time.
