Welding method for a head pipe...
Old Aug 6, 2011 | 03:18 PM
ajohnston78's Avatar
ajohnston78
if you are tig welding with er 70s there is no reason to purge the pipe with argon only would need purge with stainless or with cromoly
Old Jan 15, 2015 | 12:16 PM
MilesGlide's Avatar
MilesGlide
Stage I
Only if you mig weld with an 85/15 mix of argon/co2 with your ER70s filler material you can achieve 81,000 lbs of tensil strength per cubic inch, thus increasing the weld strength exponentially reducing HAZ
Old Jan 15, 2015 | 03:07 PM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
How about Braze-Welding with Castolin-EutecticŽ #16 and fresh Borax mixture?
This is not quite as pretty as a TIG weld but really efficient.
Old Jan 15, 2015 | 04:32 PM
billnourse's Avatar
billnourse
1st two we gutted the cats on we used TIG. Worked just fine. The last 3 have been with stick. Worked just as good. But my welder is a real pro that can do about anything. Gas, TIG, MIG, Stainless. He has worked in power plants as well as welding pipe for the oil fields.
Bill
Old Jan 15, 2015 | 04:51 PM
Uncle Larry's Avatar
Uncle Larry
How about Braze-Welding with Castolin-EutecticŽ #16 and fresh Borax mixture? ... Most of the guys here wouldn't know what you're talking about ... I had a old timer teach me ( about 45 years ago ) and he could lay a bead that looked just like a stack of dimes ... Another lost art :>(
Old Jan 15, 2015 | 05:00 PM
bagga's Avatar
bagga
i welded mine with a stick once and wire another time. if it cracks again i'll weld it again.
Old Jan 15, 2015 | 05:09 PM
fabrik8r's Avatar
fabrik8r
Originally Posted by dusty6700
I have all three machines. I mig welded mine(OFF THE BIKE) back together, simply because it faster. You can't see any of it behind the heatshield anyways. .....and i'm way better with mig, but no way can people lay down a bead with mig, and look as good as tig! Not if i'm the judge anyways! A nice tig weld is a thing of beauty!!!
Pulse MIG
Old Jan 15, 2015 | 05:52 PM
yokdriver's Avatar
yokdriver
I took my head pipe off the bike cut a window into it and then cleaned it out and then put the window i cut out back into place and tig welded it all together. Ive posted pics before as well.
Old Jan 15, 2015 | 06:20 PM
Drat's Avatar
Drat
If you do stick weld what rod are you using? 7018?
Old Jan 15, 2015 | 06:31 PM
decencyxdefied's Avatar
decencyxdefied
I've thought bout this a few times.. Cheaper than buying dual pipes or a fullsac kit
