2011 fairing removal
Old Aug 6, 2011 | 01:39 PM
crackercap's Avatar
crackercap
Default 2011 fairing removal
I need to remove my fairing on my new limited to install my garage door opener. My manual is for an 04' and evidently the procedure has changed some. I have removed the obvious screws for the windshield and only found 2 others on the side of the fairing. Where are the other screws located and "yes" I plan on getting a new manual but as of yet I have not
My senior moment guys, I forgot the 2 in the steering area and had to take bike down off of lift so I could turn wheel to get to. I had my old fairing off several times but like I said"Senior moment". Thanks again
Old Aug 6, 2011 | 01:44 PM
131tman's Avatar
131tman
Same as an '04!
Old Aug 6, 2011 | 01:48 PM
shortride's Avatar
shortride
I think there are 2 more inside of the forks aren't there? A total of 3 on each side.
Old Aug 6, 2011 | 02:11 PM
user 8373900's Avatar
user 8373900
Three hold the windshield, one each side on the outer edge and one each side up under the fairing behind the lower tree....Those are a B*TCH to get back in without a magnetic bit.
Mark
Old Aug 6, 2011 | 02:13 PM
HighLiner's Avatar
HighLiner
Put the center windshield bolt back in after you remove the windshield so the fairing doesn't fall off while you remove the other bolts
Old Aug 6, 2011 | 05:14 PM
batman4706's Avatar
batman4706
Default Fairing screws
Replace the torx with allen head ones and you can put them on a t- wrench and put them right in.
Old Aug 6, 2011 | 06:31 PM
1HarleyGuy1's Avatar
1HarleyGuy1
Mark
AMEN to this suggestion. There should be 2 bolts on each side, same as on the older models.
1HarleyGuy1
Old Aug 6, 2011 | 07:31 PM
Kesean's Avatar
Kesean
There are 7 bolts over all
3 on the windshield
2 on the inner fairing left and right side
2 under the lower tree
You have to turn the handle bars all the way to the left and all the way to the right to see and get to them.
Justinh0822
Dyna Parts
Jul 4, 2016 09:07 PM
aviscomi
2014-2024 Touring Models
Aug 17, 2014 07:49 PM
JRCinNH
Aug 5, 2014 02:59 PM
peteperrone
Jan 26, 2014 10:09 PM
VandalENG
Aug 31, 2010 10:49 PM
