I changed the Shock and fork oil in my 08' FLHX.
Old Aug 8, 2011 | 03:39 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Originally Posted by Sandcrab
I can see how you got the oil out, but did you turn the rear shock upside down to put new oil in. Seems with your setup, the shock would need to be inverted with the opening on top to put oil in and let air gurgle out. How did you do it?
Sorry I didn't photo that step... Place the shock upright in a vice and use the syringe to allow the oil to drip into the 5/16 hose...even dripping the oil into the hose you'll need to stop a few times to expell the air from the shock.. each shock takes about 45 minutes to do. 15 to drain ...30 minutes to fill.
Old Aug 8, 2011 | 03:44 PM
timberland's Avatar
timberland
Originally Posted by JustDave71
Just curious, but for getting oil in and out of the rear shocks, wouldn't a mity-vac work?
Also, on the fronts...seems it can be done using just the fork-oil drain bolts at the bottom of the sliders?
Mighty vac may work ...dunno I dont have one. A .50 5/16 hose and .50 brass fitting does work. As for removing the oil from the drain screws ...yup , that what there for. Installing ??? Works on lower units for boats so it may work.... To remove the lower inner fairing piece takes 15 minutes...clean and easy. You try the oil install with the drain screw and let us know if that works, lol.
Old Aug 14, 2011 | 09:52 PM
StevieRay59's Avatar
StevieRay59
Thanks. Did mine today using your advice and pics. Now if it stops raining I'll give her a test ride.
Old Aug 14, 2011 | 10:16 PM
Bannana Boat's Avatar
Bannana Boat
I thought my front shocks were very spongy from new. I drained and added SE Heavy Fork Oil and they are perfect now.
Old Apr 1, 2012 | 11:41 AM
aso432's Avatar
aso432
Great and easy fix for a great ride.
Thanks!
Old Apr 2, 2012 | 10:35 PM
vangasman's Avatar
vangasman
Can I assume that a 2008 road king would use the same amount of oil in each fork?
Old Apr 2, 2012 | 10:43 PM
Jeffs386's Avatar
Jeffs386
yes you are correct in that assumption
Old Apr 3, 2012 | 10:34 AM
rwb1's Avatar
rwb1
I also used a syringe to "suck " out the rear shock oil...found one with a bigger tip and threaded it int the shock....pulled the oil right out no problem.
Re-filled the same way...filled the syringe 2 oz at a time...pushed it right in..... had to release a little air when pushing it in.. worked like a charm
total process.....15 min each shock
Old Apr 3, 2012 | 11:49 AM
BlackPearl#1's Avatar
BlackPearl#1
Default 2 questions
1st do you need to put the bike on a jack to take the pressure off the forks, or just so it is straight up and down? Might wheel choke work?
2nd is would it hurt to use some of the extra ounces of oil to let run thru like a rinse? Sounds like the stuff that drains out is pretty nasty.
Thanks for a great write up and taking the time to share with all of us.
Kris
Old Apr 3, 2012 | 12:33 PM
baust55's Avatar
baust55
i have read several step buy steps how to.s on changing the fork oil in batwing type bikes .
It would be cool to see a step buy step for changing the fork oil on a RoadKing in a simalar fashion . as it is alot diffrent .
