Tour Pak Cracking
Old Aug 8, 2011 | 06:36 PM
Lowcountry Joe's Avatar
Lowcountry Joe
The upgraded tourpak hinges are beautiful. What a difference!
Old Aug 8, 2011 | 08:04 PM
02FLTR's Avatar
02FLTR
My tour pak has what looks like stress cracks all over the top of the lid. They are not cracks all the way through or anything. It's just another reason for my winter tear down for a repaint.
Old Aug 9, 2011 | 01:11 AM
V2Evo96's Avatar
V2Evo96
Originally Posted by Razerman
One suggestion on the crack repair. Drill a small hole about 1/8 on an inch ahead if the crack. What this does is, once the epoxy is in place, the crack is going to continue to the hole you drilled. Once the crack reaches the hole, the stress is relieved and the crack will stop. Also the epoxy will hold everything together better if you rough up the "inner" surface with course sandpaper and wipe clean with alcohol. hope this helps.
RR.
Drilling the crack is a MUST to keep the crack from propagating further. Make sure you find the absolute end of the crack. Sometimes cracks can run further hidden under paint, rust, etc.
Old Aug 9, 2011 | 06:50 AM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by Sgt. Fury
His tour pak is fiberglass. It's an '02.
Might help if I read better!
Old Aug 9, 2011 | 11:38 AM
piasspj's Avatar
piasspj
Originally Posted by calabera
is this a common problem with the tour pack and what are the upgraded hinges are they a dealer item??
Chrome 79211-08A
Black
53000131
http://www.harley-davidson.com/gma/g...bmLocale=en_US
matt_m_72
Nov 25, 2018 07:37 AM
BIGSKY_FLHXI
Sep 16, 2014 12:36 PM
frozensoul
Sep 1, 2014 02:51 PM
remike
Aug 20, 2011 11:29 PM
Ready2Ride
Nov 7, 2007 06:39 PM
