Can fender holes be filled or do I need a new fender?
Old Aug 9, 2011 | 08:10 AM
gtrplyr's Avatar
gtrplyr
Originally Posted by Harleypingman
You may find that you'd be better off selling your current rear fender/turn signal bar/tail light/fender tip light as a complete take-off to offset the cost of the CVO parts, including the CVO rear fender. That's what I did when I swapped out the OEM EG rear fender, etc. and replaced them with the SG fender/fascia, etc. in early '06. You can run the numbers between doing bodywork to your OEM fender versus selling the take-off parts and replacing them with a new CVO rear fender, etc.
Good luck with your project.
Carl
How difficult was it to swap over to the CVO fender? I know that they fender simply bolts on, but what about the lights/wiring?
Old Aug 9, 2011 | 08:38 AM
TexasSG's Avatar
TexasSG
'97 FLHRI fender, all holes filled & RWD extension/filler welded in. I use sheet metal plugs then weld....less heat (less distortion).
Attached Thumbnails Can fender holes be filled or do I need a new fender?-photo0037.jpg
Old Aug 9, 2011 | 10:09 AM
Harleypingman's Avatar
Harleypingman
If you haven't done so already, PM the guys who have already done this mod and they can walk you through what's involved, including the rear wiring. When I checked into doing this for a buddy's bike a year or so ago, the connector containing the rear wiring on the CVO needed to be swapped out for the OEM connector on the buddy's SG--the wiring was essentially the same, but the connectors were different.
If you want to do your own research, the HD parts books for the Touring models and the CVO parts supplement are your best friends, as are the wiring diagrams in the Touring Service Manual and CVO supplement. My dealer is very good about making those available to me for researching these types of questions when I did the SG fender swap, adding CVO speaker boxes to the fairing lowers, etc.
Carl
Old Aug 9, 2011 | 03:59 PM
stupid_rope's Avatar
stupid_rope
Carl
Yeah pull the pins and use the non-CVO plug
Mikey Ashie
Nov 27, 2020 05:38 AM
Forge
Jul 21, 2020 03:12 PM
Cagmo
Apr 24, 2020 09:56 AM
Memo7070
Jan 30, 2019 06:59 PM
Murderface
Oct 16, 2010 11:25 PM
