i just installed a 21 inch front and used both factory rotors that i polished up. but the more i look at other bikes with only one rotor the more i like them my bike has abs what would i need to do this ?
13" rotor and 6 piston - to help get the braking back. You can use your stock stuff, but not recommended.
and if you wanted to make it look clean on the right side, native custom baggers sells shaved fork legs. And as for the rim, manufacture can sell you a single side hub, so you wont have the rotor mounts on the right side..
I tried the stock caliper, and it works but I want more. HHI 6 piston will be replacing the stock stuff! Single side stuff looks great, but you still want to STOP!
