Weak clutch???
Old Aug 14, 2011 | 05:59 PM
speakerfritz's Avatar
speakerfritz
Originally Posted by Heavy D
Glad to hear that it's somewhat normal to be having this noise.
What would be your best guess on the cost of having the SE Compensator and a stronger spring installed?
225 in parts, 4 hours of labor (bill rate X hrs)
Old Aug 14, 2011 | 06:37 PM
smithbrl's Avatar
smithbrl
If the bike is still in warranty I would take it to another dealer who would hopefully know of the problem and say the comp is bad. Then ask them to install the SE comp and you pay the difference in price of the comps ($100-$150, depending on the dealer). That's what I did on mine.
Old Aug 14, 2011 | 07:11 PM
Heavy D's Avatar
Heavy D
Unfortunately, the warranty is finished. I may try the spring first on my next oil change, then see what that brings.
When you say 4 hours labor, is that because the comp change is a big job? Or is it the clutch spring that's the bigger job?
Old Aug 14, 2011 | 08:15 PM
CSP067's Avatar
CSP067
My RK does that frequently, especially when I am practicing slow-speed cone patterns. All I do is give it a little more RPM and it goes away. I think it's normal for that condition, and I don't worry about it. YMMV.
Old Aug 14, 2011 | 08:35 PM
flhtupser's Avatar
flhtupser
45 minutes to change the spring. 4 hours or so to change the compensator. The spring change is an easy task.
Old Aug 15, 2011 | 04:40 AM
Heavy D's Avatar
Heavy D
Thanks for sharing guys. Much appreciated.
Old Aug 15, 2011 | 07:51 AM
Slewfoot's Avatar
Slewfoot
Believe me now & hear me sooner:
IF you put the SE clutch spring on, you'll wish you went to the "easy-pull" clutch ramps as well, otherwise the clutch lever will pull harder than it did.....BUT....IF you have the dealer do it, you have to add a bit more to the cost.....cuz the exhause hasta be removed, & a right tranny cover gasket installed, plus new exhaust gaskets......
It cost me LOW $$$, as I did ALL the hot damn work myself......but if yer not mechanically inclined, or don't have the place/tools/shop manual or ambition to do it, then shell out the BIG BUCKS!!
Old Aug 15, 2011 | 10:25 AM
Heavy D's Avatar
Heavy D
I'll be glad I did because of the hard pull? What about this 98A spring that people are saying is right in between the stock and the SE? My father has a SE spring in his 09 Road King, and I can manage the pull, but not sure which SE spring it is. His is defintely a harder pul, but after a few hours of riding his bike, I didn't feel strain in my hands.
If the ramps are that much more $$$, maybe I can hit the gym to strengthen up instead !
Old Aug 15, 2011 | 11:17 AM
Ribitt's Avatar
Ribitt
Cool
harley sells a 10% over spring, that is easier to pull than the SE and it does work. I've got it on mine. 07 ultra
RedLewy
Sep 1, 2018 11:36 PM
mchertel
2014-2024 Touring Models
17
Sep 13, 2016 09:42 AM
ridedaddy
Mar 20, 2015 08:56 PM
Ultra103
Feb 2, 2014 10:50 AM
hotshot
Nov 27, 2008 10:32 PM
