It's not restrictive enough to reduce power on a stock or stage 1 bike. Do cams, compression, headwork, etc, and it starts to become a bottleneck. But, for the average person running around with slipons and the a/c swapped out, removing it gets you nothing on a dyno. Just posting pictures of what a cat looks like doesn't mean much, there is enough volume there to support what the engine is capable of pumping through it at WOT.
It will be cooler and the sound will be louder if you ditch it, though.
My bike with the Stage I and Rush slip-ons with the CAT runs just fine. Has plenty of power for me. I just want to reduce the heat from my right foot and leg. I want to be comfortable as possible when I ride.
I've got an '11 RKC. I put Rinehart 4" slip-ons on the bike. I left the stock head pipe in place and intact with the cat. I live in KCMO (hot & humid summers). I like the sound from the Rineharts. When sitting still (bike idling), it's hot, but not JUST from the cat, everything under my a** and the gas tank is hot. When I start rolling again, it's not bothersome. Simple.
There may be ways to boost HP or torque, but really, the bike moves my big a** where I want to go as fast as I want to get there. If I was going to race, I'd have bought a 'bussa.
I hate to point out the obvious, but sound and power aren't necessarily related.
I didn't make any inference toward power output. In fact I didn't notice any power increase at all. I merely stated that I noticed an increase in sound and not as much heat on the right side. To me, it was worth the cat removal for the heat reduction alone.
I have Stage I and Rush slip-ons on my 2010 Ultra. I'm going to remove the CAT. Dealer tells me I will need to reflash the ECM when the CAT has been removed. If the CAT is not restrictive why the the reflash?
when the dealer told you you had to reflash the ecm, what he really meant was you had to reflash 150 from your bank account to his.
WRONG !! HD stage 1 recalibration for correct VE when changing intake and exhaust. It also adjusts the timing as well as raises the redline. Well worth $150 if you are not going to do more than intake and exhaust. XiEDs ($100) would help the closed loop. Both items are a good combo for stage 1.
i'm not sure that the dealer flash actually changes the timing, have heard some say it does, and some people who really should know say it doesn't.
but my point is, just removing the cat does not require a reflash by the dealer. now with the stage 1 done, should he have some type of fuel management? sure, but again, not sure the dealer flash is the best way to go about it. no matter what, the dealer flash has to stay within epa mandated parameters. that means, still lean.
EPA is only in closed loop hence the need for XiEDs. Open loop is 12.5-13.9. Recalibration is needed for correct VE when intake and exhaust are done. For stage 1 economically $240 ish you can get the download and XiEDs and run great.
And still within EPA compliance with cats, leaving some horsepower on the table and some heat on the thighs.
Running great does not always mean fully optimized and tuned.
