The cat is exceptionally high flowing. Ceramic car cats use 50% of the space. The very tough and thin corrugated cats can be flattened to way less than 10% of the volume that they are in.
Most can not detect any change in the exhaust when the cats are removed because the flow is virtually the same.
I have a good friend who has wrenched full time on Harley's for over 30 years. Currently he does most of the performance mods, and dyno tuning for a large dealership. He has never come across an aftermarket header that will outperform the stock cat head pipe.
I tend to listen to people that have spent thousands $$$ on R&D to test that theory, like Jamie at Fuelmoto over some one who "thinks" it doesn't matter. If you look at Fuelmoto's results the proof is in the pudding and I am talking about proven dyno tuned results. The convergence of exhaust gases into a cat in my opinion cannot not result in the same flow as without the cat, other wise they would put them on everything that races down at the dragstrip.
If the cat isn't restrictive...Why did Harley redesign the mufflers when they put the cat in the head pipe?...And changed the muffler design again in 2011?
They are in the business to make money and do a good job at making a fine product. But for me, a 3 to 4 hp gain between the stock head pipe versus their $450 head pipe isn't worth it. I will never feel 3 to 4 hp.
How did you get a Cat in your exhaust pipe? Did it just crawl up in there? I would think that it would make one hell of a noise when you started it up, not to mention the furr that would fly out of that thing.
Losing the heat from the cat was worth the purchase price for me and it has a lifetime warranty.
This debate has been going on for years on the automotive side of the fence and the cats are not as restrictive as one might think.
Fuelmoto's head pipe is not a direct comparison as its still a high performance head pipe and is not a carbon copy of the stock one. To see true comparison you'll need to run a stock head pipe vs a stock head pipe with a cat removed.
If it's not restrictive then why is my exhaust louder without the cat? Because, as a secondarry effect the cat breaks up and absorbs some sound waves.
If it's not restrictive then why is my exhaust cooler without the cat? Because, the cat operates on heat, It has to get hot for the catalyst material to covert harmful gases to inert gases, it captures and retains exhaust gas heat, when it's gone the heat is gone.
If it's not restrictive then why are the mufflers redesigned for the cat? Because, again the cat absorbs some sound, so the mufflers dont need to muffle as much as a non cat system.
Just look at the picture of the cat cut in half, that has to be restrictive. Yeah, look at it, closely, the total open area of the cat material mesh is more than sufficient area to support the volume of flow required by the primaries.
Just looking at a cat lets me know just how restrictive they are. Glad to get rid of mine. The way it holds heat down there has to be a clue how they hold the heat.
Full Sac Performance did it, back to back dyno, same bike with and without the cat in the OEM pipe, ZERO difference in measured power output.
