I don't dispute the fact that the cat is a pretty good heat source that's for sure......but I'm not sure how restrictive it is based on me putting new pipes on yesterday.
I installed Supertrapp SE's, ones designed for 10-12 bikes that have the cat in the headpipe. Straight through design with any internal blockage that you see (or can't see) in other pipes. Can see clear through to the other side.
I fired up the RK and walked behind to see how it sounded from the back. I was about 8-10 feet behind the bike and I could feel the exhaust hitting me in the shins, something I could not detect with the OEM exhaust at even a closer distance. And it was pumping out pretty good like an air hose hitting me.
I don't think that the cat is really that much of a blockage as we might think...just an observation and I certainly understand why some folks do have it removed. ...
Leave it in, it doesn't matter to us whether you do or not..
If you're happy w/it leave it alone.
You don't need our permission..
if you want to leave it in. or buy another one w/the cat in gut out the pipe and then put it back on and then put the one with the cat back on for comparison sake.
THEN YOU WILL KNOW...
They are in the business to make money and do a good job at making a fine product. But for me, a 3 to 4 hp gain between the stock head pipe versus their $450 head pipe isn't worth it. I will never feel 3 to 4 hp.
I could and I believe it was more like 7 or 8, not 3 or 4.
With all due respect...I find that hard to believe...Just the fact that the bikes with a cat is so much hotter than a bike without a cat is an indication that they are restrictive...Look at the picture Texas fatboy posted...How can that not be restrictive?
The cat does it's job as a catylist and heats exhaust and removes the bad stuff. This is a chemical activity and produces the heat, not the heat produced by being restricted, my 2 cents.
I was just observing that since I put the Supertrapps on that the amount of "felt" exhaust while standing behind the bike has increased dramatically. In my totally unscientific observation to me the restriction seemed to more a result of the oem mufflers vs the cat
If it's not restrictive then why is my exhaust louder without the cat? Because, as a secondarry effect the cat breaks up and absorbs some sound waves.
If it's not restrictive then why is my exhaust cooler without the cat? Because, the cat operates on heat, It has to get hot for the catalyst material to covert harmful gases to inert gases, it captures and retains exhaust gas heat, when it's gone the heat is gone.
If it's not restrictive then why are the mufflers redesigned for the cat? Because, again the cat absorbs some sound, so the mufflers dont need to muffle as much as a non cat system.
Just look at the picture of the cat cut in half, that has to be restrictive. Yeah, look at it, closely, the total open area of the cat material mesh is more than sufficient area to support the volume of flow required by the primaries.
It's simply not restrictive.
We will just have to agree to disagree...You are free to believe what you want...I will not try to convince you otherwise.
Full Sac Performance did it, back to back dyno, same bike with and without the cat in the OEM pipe, ZERO difference in measured power output.
These are the same results seen in the automotive industry, but they still sell "Hi-Flo" Cats, wait a while Harley will start selling these "Hi-Flo" Cats for all these people that think the stock cat is restrictive and want to keep there bikes emission compliant.
This debate has been going on for years on the automotive side of the fence and the cats are not as restrictive as one might think.
Fuelmoto's head pipe is not a direct comparison as its still a high performance head pipe and is not a carbon copy of the stock one. To see true comparison you'll need to run a stock head pipe vs a stock head pipe with a cat removed.
Someone did post dyno results a while ago with stock head pipe and exhaust and stock head pipe gutted and stock exhaust There was no performance gain. The restriction is the A/C and slipons granted the heat issue on your leg may be worth the pipe alone.
The cat is exceptionally high flowing. Ceramic car cats use 50% of the space. The very tough and thin corrugated cats can be flattened to way less than 10% of the volume that they are in.
The volume that they can be reduced to is in no way directly related to the percent of restriction given the " pleated " shape throughout the contour flowing through the honeycomb ..and as carbon builds over time the restriction percentage would become greater .
I gutted my cat and during decel you can clearly notice a HUGE reduction in the amount of backpressure ..
The shape and contour of a given mass is what would deem its amount of restriction. Just because an umbrella could be reduced to a trivial volume doesn't mean you couldn't block some wind with it ...
I have ran two bikes stock with the cat in and removed. My 2010 RK and my wife's 2010 SG Trike. I posted video's on how they sound with and without the cat. I could tell a little increase in power on my RK because I went to 2into1 exhaust. My wife's SG didn't add any power. In fact, she said other than a little less heat and louder exhaust, she felt like it was less power than with the cat. My final diagnosis is, the cat does not restrict flow, only add's heat!. I put her bike back stock to trade it. I've installed the Arlen ness big sucker air filter and dyna tuned Jackpot's on the 2012 Triglide we just bought. I'm leaving the cat in this one. Most of my riding is in these Tennessee mtn's. With a Captain Itch Crotch cooler, the heat from the cat is not a problem.
