clutch lever
Old Aug 15, 2011 | 04:24 PM
vailtl's Avatar
vailtl
Default clutch lever
After adjusting clutch & lever cable is it ok for the lever to not come all the way to the bar.
Mine is now 1/2 inch away from handle bar when squeezing.
Anyone thanks.
Old Aug 15, 2011 | 04:55 PM
dawg's Avatar
dawg
Sounds like you didn't adjust it properly. Do you mean it engages 1/2" off the bar as you let it out or did you mean that you cannot pull it all the way back to the bar when pulling it in?
Old Aug 15, 2011 | 05:55 PM
vailtl's Avatar
vailtl
Default thanks
Thanks, I mean the lever does not go all the way to the bar.
I readjusted using The nickel trick it seeps ok now.
tomoad
Sep 30, 2018 04:04 PM
Voldemort
Aug 15, 2013 06:08 PM
2XNightTrain
Oct 4, 2009 01:29 PM
2008FLHP
Aug 27, 2008 05:08 PM
HDF Tech
Jul 3, 2005 05:29 PM
