2011 Road Glide 96" dyno results!
Old Aug 15, 2011 | 07:35 PM
MichiganRider's Avatar
MichiganRider
Default 2011 Road Glide 96" dyno results!
Took it in for the 1000 miles service (actual 757 miles). The dealer did a stage 1 (which was included when I bought the bike). I upgraded the slipons to black Rinehart Extreme true duals, SE AC & tuner, here you go:
Front cylinder 70.45 hp, 80.12 torque
Rear cylinder 72.45 hp, 81.18 torque
Do you just average the two? Not used to this. I think the numbers are ok. At least the bike shifts a lot better, finds neutral much easier, runs cooler, etc.
Old Aug 16, 2011 | 06:29 AM
MichiganRider
Why is there a seperate run for each cylinder? Shouldn't there be a final pull for the actual horsepower and torque from the engine? Can someone please explain this to me?
Old Aug 16, 2011 | 08:47 AM
Coolhawg6622's Avatar
Coolhawg6622
There isnt...........there combined.... ..total output.......no idea why its listed that way but they dont read separate cylinders as its measured at the rear wheel..
Old Aug 16, 2011 | 11:55 AM
MichiganRider
That makes sense. The numbers seemed low compared to my old '02 Road King. It had a stage II 95", stock heads, Rinehart true duals, AC, & cams. Just a generic dealer build that made 80.38 hp, 92.78 tq
I guess cams make a big difference! I know too many variables to compare. But still quite a difference in peak torque....
Old Aug 16, 2011 | 08:15 PM
CtCruzer's Avatar
CtCruzer
I think it means air/fuel ratio taken at ft then on rear to check
most machines only have 1 probe
Dymnd Dave
Jul 28, 2011 04:15 PM
jetsled
Jan 22, 2011 09:24 AM
C-Man
Jun 14, 2010 08:18 PM
2008hdman1
May 30, 2010 05:38 AM
AggieFan
Mar 16, 2007 06:09 PM
