Did they do me wrong...?
Added upgrades to the purchase of my 2011 103 SG.
SE AC w/stock cover
SE Tuner
255e Cam's (talked out of 259e) with adjustable pushrods
Bassani's Covington's Hot Rod True Duals (my choice)
Was told I'd get around 90ish HP and around 100 ft lbs torque...rec's came from parts guy...not service...!
I should have discussed with service, my error.
So having said that, pipes look and sound good. SG Run's great...!
However it Dyno'd at 78.9 HP & 98.8 ft lbs Torque after the mods.
They did not do a dyno before work to show difference.
I know you loose a bit of HP with true duals but I thought I'd surely get more than 79hp....!
Comments...am I whinning for nothing....?
Thanks,
The videos pretty much show's me having more power then their set up...????
Just was expecting more HP...but knowing the Ft Lbs of Torque is good
example... a friend did
259e's / D&D 2-1 / SE tuner / Heavy breather with 97hp & 107 Ft Lbs Torque
Buddy of mine has similar setup as you on a 2010 103" FLHX... stage 1 a/c, 255's, SEPST, V&H power duals with Monster Rounds.. dyno'd right about 83 HP and 100 tq..
