Fullsac
Old Nov 17, 2006 | 09:03 AM
211Chuck's Avatar
211Chuck
Default RE: Fullsac
ORIGINAL: HEYENG
Installed fullsac today took less then 2 hours huge difference in the sound and great looks what a deal for $179.00
Can you get the left side body plastic side cover off without
taking the rear cylinder pipe loose or off???
I've been told you can't and if you blew a fuse out on the
road that could be a problem..
Old Nov 17, 2006 | 09:12 AM
dchoran's Avatar
dchoran
Default RE: Fullsac
Brad - thanks for the pic and explanation on the install - got it. Really just removing the pipe from the rear cyl going to the right exhaust.
Wouldn't you need to retune/dyno if fuel injected??? Seems like a major change.
211Chuck Date 11/17/2006 6:03:16 AM
quote:
ORIGINAL: HEYENG
GOOD QUESTION Chuck - that would be a showstopper for me.
Do you in fact have to loosen up the left pipe to access your fuse block on an Ultra - can anybody confirm/deny this???
THANKS.
Old Nov 17, 2006 | 10:23 AM
bradteed's Avatar
bradteed
Default RE: Fullsac
Everything that I have read and discussed with Fullsac and Torres doesn't require a "retune". Also, I have read several posts where people confirmed that you can indeed get access to the sidecover after the installation.
Old Nov 17, 2006 | 10:40 AM
bradteed's Avatar
bradteed
Default RE: Fullsac
According to this thread here the exhaust position doesn't change and the side cover is fully accessible. Also, if you read the Fullsac info, a remap or tune isn't required.
Old Nov 17, 2006 | 10:41 AM
FLHT's Avatar
FLHT
Default RE: Fullsac
Here is another thread on the Fullasc conversion with some pics of it installed.
https://www.hdforums.com/m_916025/tm.htm
QC
Jan 15, 2014 07:57 AM
steelerdude1
Nov 12, 2013 09:07 PM
PHA-Q
Mar 10, 2012 09:00 AM
OLD 96
Mar 13, 2011 06:42 PM
Hogbroke
Jan 25, 2008 03:57 PM
