Have a 'Doo or Yammy motor? Guessing it's an asphalt sled? Or run the ice?
Did lots of grass running up here.. Wouldn't having the pipes running cooler slow down the exhaust pulses, leaving you with a richer condition?
Originally Posted by Bill03E
I do know that I had the pipes on my drag sled coated , they did the inside , it lowered the RPMs (2 Stroke) and I burned the motor down, because it leaned it out too much, my mistake for not checking .
I don't know if it would do so much on a V twin motor, mine was a 700 triple.
I love my Cycle Shack slip-ons and cant decided between the jackpot headers or fullsac. I'm sure its going to sound a lot better either way.
Originally Posted by Rickr01
Cool stuff, thanks. I currently have my 02 sensors disconnected anyway because I'm running a PCV on a 10 Street Glide. I also run the Pro Pipe and Stage 1 air cleaner. I like the look of the Pro Pipe and all, but I still really like the sound of the Cycle Shack exhaust better than any expensive system I've ever run. I keep coming back to Cycle Shack. I asked because I'm going to have my stock 2-1 head pipe gutted, (it did do a lot to cool the engine down by changing to a catless set up), and trying a Cycle Shack Muffler on this bike as well. I have to say that by removing the stock set up and going catless, I did indeed feel as though I lost something in the low end grunt? But over all the bike seems to run smoother.
Can you explain "lowered the RPMs"? The relationship between engine rpm and vehicle speed is mechanical. xxxx rpm = xx mph always unless you change gearing. Coating the pipe won't change that relationship.
Yup, after coating my header, my muffler got a gold hot spot. If the ceramic prevents the heat from transfering through the pipe material then it must be exiting out the hole in the end of the pipe, hence higher temps in the muffler.
Same issue here. I'm thinking that the ceramic coated heat shield isn't helping either.
Seems to me like you've nailed it fabrik8r. Ceramic is real good at insulating heat and I suspect that IF ceramic coating is only done on one surface, then inside the pipe is the most efficient and pipes done on both surfaces will please those who truly are "on the dark side".
Yep - I (for one) agree completely with your conclusion. I bet any ceramic coated pipe with chrome on the outside was built that way because some owners prefer their pipes chromed and the manufacturer decided to offer them.
What you discovered seems to say that if you get a ceramic coated (internally) but chromed (externally) pipe, then you probably need to find the same sort of muff too.
It also shows that heat is well contained while inside a ceramic tube (whether or not that ceramic tube is on the inside or the outside of a metal tube).
Okay, so who thinks they know something about ceramic coated headers?
Both company A and company B have stepped headers. Company A puts the ceramic coating on the inside of the pipes and company B puts it on the outside of the pipes.
Is there an advantage to one way versus the other?
Is there less heat with one over the other?
How about performance wise?
Pushing the heat out the back?
Thanks for the input!
We all know the ceramic coating is a great insulator. The main advantage of ceramic coating the inside is it prevents the heat from ever transferring into the metal. Basically is forces the heat out with the exhaust before the pipe can absorb it. If you coat just the outside, the metal will absorb the heat and the outside coating is now insulating heated metal. This is not effective and the main reason we also coat the inside.
When coating both sides, we have seen well over 300 deg heat reductions directly on the headpipe near the jugs. We are confident that all of our customers will experience at least a 300 deg reduction directly on the head pipe. When testing with just the outside coating we had very poor results. I do not have exact numbers, maybe 100 deg reduction, but they were so poor if forced us to coat the inside as well.
Performance will not be affected by the ceramic coating. The only time you will see a difference in performance is on very high end racing machines where a very small gain could mean the win.
The exhaust heat will be blown out the back but it's not a big change. We have not received any negative feedback about this over the past 4 years.
Please keep in mind that coating the inside requires specialized spray guns to fully cover the pipe and doubles the cost of coating. We offer this standard on all of our true duals and full systems. The benefits of the inside/out coating were too great to not do it.
-Ryan
I've never seen a dyno comparison between a Rinehart system (or the Fulsac) and the (for example) Jackpot. I'd be curious to see what the difference is, if any. I do know that Jamie tested a pile of pipes before releasing his, and all his testing confirmed that a non-stepped header performed the best up to around 125 horsepower.
That would be interesting and I have been looking for comparison of RH TDs with any other system but haven't found any data. I do believe that, as TDs go, the Rinehart system is the best performing and best sounding.
Originally Posted by 05train
That's a valid question that I simply don't have the answer to. All I can do is point to the manufacturer of the pipe I'm using who told me that stepping the header was unnecessary, and the various references on ze Interwebz which refer to stepping as less than ideal.
Gonna take a wild guess on this one. The manufacturer doesn't offer a stepped head pipe because of all the test data that they have supporting that stepping head pipe was unnecessary. I know you are smarter than to believe everything you read on the internet.
