Engine temp vs Oil temp
Old Aug 24, 2011 | 11:15 PM
hover's Avatar
hover
Ok, thanks everyone, it sounds like the oil temps on my bike are nothing to worry about. I just didn't know how far apart the ET and OT were gonna be. Sounds like OT is about 30 or so lower than the ET.
Old Aug 24, 2011 | 11:24 PM
Sam2010's Avatar
Sam2010
Originally Posted by hover
If the ET readout on my Powervision says the engine is running at 270 on a 90 degree day(out on the highway), would the oil temperature be actually lower or higher and approx. how much? I don't have an oil temp gauge. The bike runs about 240-250 on a normal 70-80 degree day...the 270 temp indicated seems high for a Stage 1.
I wish my bike ran that cool.
Old Aug 24, 2011 | 11:50 PM
myred55's Avatar
myred55
Originally Posted by mkguitar
don't worry about it- an oil cooler can help- and it slightly increases capacity- but really.
Look where you live, look where I live.
I have all kinda bikes and cars and they still work, everyday.
parade fan might help if you are sitting close to still, otherwise when moving it may impede cooling air from flowing around the motor.
And--- for those who are really worried, fairing lowers contribute to lower motor and oil temps. The fairing lowers "order" the air and direct it toward the motor.
Think of air as a fluid--- that big dumb rotataing wheel and that fender cause a messy bunch of air which is not smoothly directed at he motor- the fairing lowers help.
on an average day of 105ş my oil was measured 25ş cooler with the lowers on than off, consecutive runs on the same 20 mile piece of hiway.
mike
Very interesting.......I guess I'll put my fairing lowers back on during the hot summer months.
Old Aug 25, 2011 | 03:21 AM
Watch Guy's Avatar
Watch Guy
Default These new devices are going to drive us crazy
with worrying about engine temp and oil temp readings. I believe this is far too much info for the average rider and the quest for a bike that runs cold will always be elusive. I'm not concerned with 260 degree oil temp and god knows what the head temp is at any given moment. HD has been making air cooled engines for over a century and that was with crude and unsophisticated oils and they ran quite well. I can't believe how obsessed we have become with all these gadgets that give us info we really don't need (or understand) I've had liquid cooled bikes that ran just as hot as my RK in the summer.
Old Aug 25, 2011 | 05:25 AM
Bodean46's Avatar
Bodean46
Just reading that MoCo is bringing out a water cooled RG Ultra for 2012. Wonder what ET and OT on this will be.
Old Aug 25, 2011 | 06:26 AM
fabrik8r's Avatar
fabrik8r
I just read back through this thread and I didn't get out of it what you did. Sounds like you have interpreted exactly what you wanted to hear. I've been closely monitoring my temperatures for a couple years while developing cooling systems and I can assure you that there is no way to convert ET to OT, just too many variables.
Old Aug 25, 2011 | 07:55 AM
speakerfritz's Avatar
speakerfritz
oil will be lower. your eng temp is coming from a sensor located on the heads which is the hottest part of the bike.
Old Aug 25, 2011 | 08:04 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I pay no attention to any of it. I buy good synthetic oil and forget about it. My engine hasn't melted yet. If you have an oil cooler...you should be good to go anywhere.
Old Aug 25, 2011 | 08:24 AM
RAP's Avatar
RAP
Watch Guy, you are 100% right!
Old Aug 25, 2011 | 11:50 AM
iclick's Avatar
iclick
ET (Engine Temp. measured on the front head) and OT (oil temp., usually measured in the pan) are very different readings, and Fabrik8r did a good job of describing the relationship. I've monitored both for over a year on my '07 and have seen as much as 100° difference between the two, and like Fabrik8r said there is no way you can infer one from the other, except that on my bike at least ET will always be higher than OT. Well, I suppose maybe if you were in a strong wind and let the bike sit for 20 min. the head might cool fast enough to settle below OT at some point in time, but that would be a rare event. ET fluctuates much more rapidly, and IMO is the best measure for real-time engine temp. OT is a slower movement and will generally stay lower than ET, usually considerably so.
What engine configuration do you have? The 103's I've seen run hotter than 96's, more than would seem warranted by a displacement and compression increase alone. My 96" with 255 cams and lowers runs 225-235° ET on the highway in this 95-100° weather, but at 60° it will barely tip 200°. This bike runs cooler than most for some reason, and oil temps stay sane too, rarely >205° with 230° being the highest I've seen in 4˝ years (gridlock traffic in summer). What makes it even more odd is that I run stoich in the cruise range (14.6:1) and around 14.0 at idle, which by conventional thinking should make the bike run hot as hell. This summer has been the hottest on record here and ET hasn't exceeded 290° yet, OT at 220° a few times, but that high only in heavy traffic. If I had EITMS working, which I don't, it would kick in at 290° ET, so it would be a rare event. EITMS is available for the '07 but only on one firmware version, which I had at one time but currently don't. Other models will activate at different ET's, but I understand it is generally 285-290°.
I believe a critical component to engine cooling is an oil cooler, and I have an HD cooler installed here. I wouldn't want to ride without one, but I've seen a few 103's that run hot like yours even with a cooler.
HD claims that lowers can actually help cooling when the bike is moving, but they can trap air when stationary. MKguitar has made the same observations, but others claim they make their bikes run hotter. I find that they help with cooling on my bike, though not as much as MKguitar has observed, as I've had them installed for 3˝ years and have found temps to be a tad cooler (maybe 5°) while moving. When stopped I have seen no changes. I think with their wedge shape they scoop more air and drive it into the engine, and they might even improve flow at the cooler.
Originally Posted by 1931JamesW
Anyone know for certain when the EITMS activates?
Depends on the year-model. My '07 would activate at exactly 290° ET, but based on reports here later models can be different. I don't know if it varies from bike to bike within year-models, but I doubt it.
cajun1957a
Shovelhead
Dec 31, 2024 04:57 PM
Big Dave
Aug 11, 2016 06:11 AM
uwiik
Oct 22, 2013 08:41 AM
RandyD123
May 17, 2006 11:08 AM
shepster
May 9, 2006 08:42 PM
