A weird one...
Old Aug 23, 2011 | 11:23 PM
mediamike19063's Avatar
mediamike19063
Default A weird one...
It's kind of hard to explain but whenever I disengage the clutch it sounds like the RPM's continue wherever they were last for a good second or two after pulling in the clutch lever. I have a 2003 RK FLHCRI with Big Shot Duals, FM PCIII and stage I air cleaner. Would a bad clutch cause this? Sticking throttle? I'm lost for ideas here as I have never had this happen before.
Thanks for helpin' out a noob!
Mike
Old Aug 23, 2011 | 11:29 PM
soft 02's Avatar
soft 02
Is your tension screw on your throttle a little tight?
Old Aug 24, 2011 | 07:26 AM
mediamike19063
You know what...it probably is....I like a tighter throttle and may have cranked it a little tight...I'm about to go out so I will loosen that up and see what happens. I hadn't realized that could be the culprit. Thanks!
Mike
Old Aug 24, 2011 | 07:33 AM
shortride's Avatar
shortride
Sometimes I catch myself. Not letting off of the throttle quickly enough before disengaging the clutch.
Old Aug 24, 2011 | 08:59 AM
xpilot's Avatar
xpilot
Mine does the same thing occasionally. I'm thinking that it may be either the IAC ot TP sensor starting to go bad.
Old Aug 24, 2011 | 04:51 PM
El Rey's Avatar
El Rey
Same here. Occasionally.
Old Aug 28, 2011 | 05:45 PM
mediamike19063
I tried tightening and loosening it up and a little looser makes it slightly better but not a fix. It still does it! Any ideas ladies and gents? Thanks a lot for all your help again.
Mike
Old Aug 28, 2011 | 06:11 PM
Teardrop's Avatar
Teardrop
Try lubing the throttle cables..
Old Aug 28, 2011 | 06:44 PM
rhlhamlet's Avatar
rhlhamlet
Sounds more like a throttle problem than a clutch problem.
Old Aug 28, 2011 | 06:48 PM
steelerdude1's Avatar
steelerdude1
Mine does the exact same thing, and has since I bought it (used) I just shool it off as a Harley thing. I'll be watching this thread.
