Cat Headers are so bad?
Old Aug 25, 2011 | 01:15 PM
Hammerhead Pat's Avatar
Hammerhead Pat
If you ride alot in cold weather, keep the cat so you won't have to buy thermals!! It's like your motor has asthma with the cat in the pipe, I just don't buy the theory that it isn't restrictive after cutting mine out and seeing it for myself!!!
Old Aug 25, 2011 | 01:32 PM
TUCCI's Avatar
TUCCI
Originally Posted by mtclassic
while I agree with you that they don't have a big effect on flowI will say they do take up a lot more then 10% of the container volume. I cut one and removed the cat material and I would estimate it was closer to 50% which still left plenty of flow. look up the header pipe and you can see exactly what the stuff looks like. When you cut the section in two you can hold it up to the light and you can see it looks like about 1/2 material 1/2 free space.
Oh my god yes....it made a huge diff in removing the heat, and the tone changed to that of a slip on pipe.
Old Aug 25, 2011 | 01:39 PM
TORQUEY's Avatar
TORQUEY
The cat elimination made a startling difference in performance, at least as much as replacing my stock air cleaner with a stage 2 Big Sucker.
And yes, it is more restrictive than the North Korean Gov't.
Old Aug 25, 2011 | 03:17 PM
GPHDXLC's Avatar
GPHDXLC
I put 1000 miles on my 11 RK completely stock, even with the windshield off I could feel heat on my right leg all the time, even on the freeway. Next I put on Bassani 4" megaphones, sound was great but the heat was the same. About 1500 miles later I got a no cat 09 head pipe and a FM mapped PCV and a SE air kit. Now without the windshield I cant feel the heat unless I'm going slow in traffic, big improvement. Only down side for me anyway is with out the cat the megaphones are a lot louder, sometimes on long rides they get to be a little to loud. I don't know how much the cat restricts the air flow, but they make a big deference in the sound and the heat on the right side.
Rdcris
2014-2024 Touring Models
17
Jan 5, 2021 09:04 PM
tt_ksu
Mar 20, 2016 04:58 PM
2011FXDC
Rush Racing Products
Oct 13, 2014 02:49 PM
Granpita
Nov 21, 2013 10:08 AM
SpiderPig
Feb 1, 2011 08:30 AM
