Changing exhaust gaskets
Old Aug 25, 2011 | 02:18 PM
Udawg's Avatar
Udawg
Default Changing exhaust gaskets
I just removed the cat on a 2011 FLHTK and the exhaust gaskets stayed on the motor and look good. Is it necessary to replace the gaskets or just reuse them since and I am re-using the same pipes?
Old Aug 25, 2011 | 02:28 PM
CHOPPIN' CHARLIE's Avatar
CHOPPIN' CHARLIE
I ain't a mechanic by no means but I have read when opening an exhaust to replace all gaskets and hardware. Bolts, nuts, and clamps all streach and fatigued. Gaskets loose their flexibility to seal properlly. I understand an exhaust leak leads to backfire and other problems.
Old Aug 25, 2011 | 02:30 PM
KCFLHRC's Avatar
KCFLHRC
Yep, replace them. You are also suppose to replace the muffler clamps.
Old Aug 25, 2011 | 02:36 PM
Udawg's Avatar
Udawg
Thanks I had never heard that.
Old Aug 25, 2011 | 02:37 PM
Udawg's Avatar
Udawg
That's just where the muffler clamps to the pipe right?
Old Aug 25, 2011 | 02:38 PM
KCFLHRC's Avatar
KCFLHRC
Correct
Old Aug 25, 2011 | 02:44 PM
Udawg's Avatar
Udawg
Correct
Thanks KC, I'll try to go get them now and get it running tonight then I get to try it out tomorrow. I thought about wrapping the chamber where the cat was with ceramic wrap but I'm hoping I won't need it.
Old Aug 25, 2011 | 03:01 PM
KCFLHRC's Avatar
KCFLHRC
I actually bought the wrap but never used it. I painted the area where it was welded with high temp paint. It makes a lot of difference. It still gets hot but not near as bad as it was.
Old Aug 25, 2011 | 03:18 PM
Udawg's Avatar
Udawg
Any trick to getting the old gaskets out of the heads.? I don't want to scratch them up any. These are like they are glued in.
Old Aug 25, 2011 | 04:44 PM
RK4ME's Avatar
RK4ME
Just pick them out with a very small screwdriver or pick, which can be found at Autozone. Follow the instructions in the Harley Davidson Shop Manual when installing the exhaust system.
