Check your lower transmission bolts that secure the exhaust hanger, mine were loose and allowed the gearset to walk enough to tweak the neutral switch.
Thanks guys. I just haven't taken the time to look at it yet. Should be easy enough when I get around to it, just wanted some good input from others who've had the same issue. I'm kinda like you, it ain't messing anything else up right now so I'll get to it when I get a round tuit. Later
Check the pin connectors on the switch, I looked at mine last winter and they had green corrosion built up, I cleaned them out and put dielectric grease on them. Mine also did the same as yours when bike was new, as someone said just replace the switch, quick and easy.
