Neutral light issues.
Old Aug 25, 2011 | 07:09 PM
VooDoo13's Avatar
VooDoo13
Default Neutral light issues.
So the other day I noticed my neutral light was flicking while shifting gears. Then next thing I know it comes on and stays. It slowly fades like a battery going dead. Any Ideas.
Old Aug 25, 2011 | 07:27 PM
knewt5's Avatar
knewt5
Bad Neutral switch
Old Aug 25, 2011 | 07:34 PM
VooDoo13's Avatar
VooDoo13
I don't wanna deal with the dealer bs when I can just do this myself. Now to find a part# And do it to it. Thanks
Old Aug 25, 2011 | 10:07 PM
Potato_Potato's Avatar
Potato_Potato
Sometimes just taking the switch out and cleaning it will fix it.
Old Aug 26, 2011 | 08:44 PM
VooDoo13's Avatar
VooDoo13
Well it seems to only be an issue when I have ridden 50+ miles. Like When it gets good and hot.
Old Oct 13, 2011 | 01:31 PM
StreetGeezer's Avatar
StreetGeezer
VooDoo - did you ever get this issue fixed? My light just started doing the same thing the other day.
Old Oct 13, 2011 | 03:46 PM
VooDoo13's Avatar
VooDoo13
no i just ignore it. I will fix it when I get the next service.
Old Oct 13, 2011 | 06:11 PM
07standard's Avatar
07standard
mine was doing the same thing.. i swapped out the switch in 2 mins and its good to go. the switch was under $10. 15/16 socket if i remember correctly... right on top of the trans with two wires connected to it.. easy stuff..
Old Oct 13, 2011 | 06:15 PM
skydude426's Avatar
skydude426
Mine stayed on all the time. Replaced the switch and it's all good. Easy fix.
Old Oct 13, 2011 | 06:26 PM
StreetGeezer
Thanks guys. I just haven't taken the time to look at it yet. Should be easy enough when I get around to it, just wanted some good input from others who've had the same issue. I'm kinda like you, it ain't messing anything else up right now so I'll get to it when I get a round tuit. Later
