Anyone Using Car Speakers in there batwing????
Old Aug 26, 2011 | 09:59 AM
Medicjaycook's Avatar
Medicjaycook
Default Anyone Using Car Speakers in there batwing????
Can standard car audio speakers be used in place of stock speakers, Im putting a Sony Head Unit into my bike this weekend, and got a line up on some good speakers? what are the pro's and cons of using standard speakers?
Old Aug 26, 2011 | 10:09 AM
streetglide44's Avatar
streetglide44
POLK Audio are rated for marine use but used for both.
Old Aug 26, 2011 | 10:10 AM
SG Mike's Avatar
SG Mike
Yes you can use standard speakers but the downside is regular speakers with paper cones are can/will warp from moisture.
I put Kappa Infinity 62.9i which have a polypropylene coating that will work. So if you are looking for speakers just make sure that are poly's.
Mike
Old Aug 26, 2011 | 10:38 AM
mkguitar's Avatar
mkguitar
BUT paper speaker cones can be scotchguarded- just follow the instruction on the can, do the front and as much of the rear as you can cover- a light coating is best. A heavy coating will dampen the speakers transient response
You don't want to aim the hose right at them on washday.
Mike
Old Aug 26, 2011 | 11:10 AM
jndr756's Avatar
jndr756
I was wonderin the same thing. I got j&m 7.25's and amp right now but thinkin bout takin them out and putting some small subs in batwing and a tweeter pod.
Old Aug 26, 2011 | 05:07 PM
lkr0's Avatar
lkr0
go with Infinity's I have them in my RG; went with JBL's on my SG -- they suck badly -- changing them out as soon as I can
Old Aug 26, 2011 | 10:49 PM
JoeFriday77's Avatar
JoeFriday77
I just installed 4 of these puppies. They sound pretty good in the garage. We'll see how they do on the test ride tomorrow.
Polk 5.25's
Old Aug 26, 2011 | 11:05 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Originally Posted by Medicjaycook
Can standard car audio speakers be used in place of stock speakers .........................
Yes, but they won't last long.
Old Aug 27, 2011 | 02:28 AM
DTTJGlide's Avatar
DTTJGlide
Why??
Old Aug 27, 2011 | 03:47 AM
streetglide44
When buying speakers keep in mind that there are low end to top end performance speakers of all major brands. Just because someone doesn't like a particular speaker doesn't mean entire line is bad. Everyone's ears are different, some prefer more highs other miss and so forth. Wind noise,speed, exhaust noise, windshield highth, ambient noises all factor into depletion of sound quality. Amps definitely help, good luck. Keep in mind that component speakers always sound better than two way speakers. You just have to find location for tweeters.
