front bearing failed 2008 streetglide
Old Aug 28, 2011 | 06:29 PM
mike08sg's Avatar
mike08sg
Default front bearing failed 2008 streetglide
changing front tire and found right side bearing missing some *****,I've looked and can't find a timpkin or after market part #,can any body help me.
Old Aug 28, 2011 | 06:46 PM
m361's Avatar
m361
Sorry...I know you are looking for some assistance, but if you don't mind me asking...how many miles do you have on it? I also have an '08 SG. Wondering if this is something I need to check soon. Did you have some symptoms or just found it when you were changing the tire?
Old Aug 28, 2011 | 06:48 PM
speedwaysteve's Avatar
speedwaysteve
I posted thread on the same thing,dawg posted the bearing part numbers,the thread starts with check your bearings
Old Aug 28, 2011 | 06:53 PM
ramnj's Avatar
ramnj
I have a friend that the same thing happened on her 08 SG and the repair was covered iunder warranty.
Old Aug 28, 2011 | 06:56 PM
speedwaysteve
I had tires done at 16k on my 10 sg had some noisys dealer replaced front and rear bearing while doing the tire change
Old Aug 28, 2011 | 07:06 PM
69cj's Avatar
69cj
I found an a/m bearing thru a commercial bearing house. Replaced all four. Had a front failure in less than 2,000 miles. Went back to the HD's at double the price. They are now made in Slovakia instead of China if that makes a diff.
Old Aug 28, 2011 | 07:18 PM
mike08sg's Avatar
mike08sg
16,300 miles,found while changing front tire for 7000 mile trip,budies bike has 12000 miles on it and they are failing as well( missing *****)and those part #'s 9252 are they for hd or aftermarket
m361's Avatar
m361
So are there any tell-tell symptoms to watch for when the bearings are going bad or is this something you can only find during a tire change?
Old Aug 28, 2011 | 07:21 PM
mike08sg's Avatar
mike08sg
oops I forgot to say i have ABS
Old Aug 28, 2011 | 07:28 PM
m361's Avatar
m361
Oh...I don't have ABS. So...is this an ABS related issue then? I just went over 14k miles and I haven't noticed anything unusual up front.
