SE Comp
Old Aug 29, 2011 | 12:15 PM
rkoivisto's Avatar
rkoivisto
Default SE Comp
I've got a 83935-09 on order at Zanotti's. It's back ordered and when I checked on it today, they said it was being obsoleted. They are supposed to have some info on 8/31 about it.
Suppose they are fixing it?
Old Aug 29, 2011 | 12:18 PM
soft 02's Avatar
soft 02
Is that the OEM comp. If so dont do it. Get the SE one.
Old Aug 29, 2011 | 12:33 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I agree 100%!! Get the SE compensator. HD part number 40274-08. Hope that helps! The SE comp should be readily available. We order and install them all the time!
Shawn
Old Aug 29, 2011 | 12:51 PM
rkoivisto's Avatar
rkoivisto
Default SCREAMING EAGLE Comp
The SE in the title is for Screaming Eagle. There has been a lot of dissatisfied people with the milage they get on the SE comp. I got about 30K on mine and it's making a lot of noise.
HTT has had a lot of dissatisfied SE comp threads. The part number I listed is for the three parts that fail and something is up at Harley with these kits.
I was just hoping they are improving them so they last longer.
Old Aug 29, 2011 | 12:59 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
We have had great luck with them so far. The stock comp lasts about (25K-30K) amount of miles. We have installed dozens of them and so far, no reports of failure or noise. We fill the primary with Amsoil 20W50 after installing them.
Shawn
Old Aug 29, 2011 | 01:01 PM
Dirt-Kid's Avatar
Dirt-Kid
Besides noise,what are the symtoms of the stock compensator going out/bad?
Old Aug 29, 2011 | 01:25 PM
rkoivisto's Avatar
rkoivisto
Default comp
Stock one you get a lot of hard starting, clanging and sometimes vibration at about 3K RPM.
Old Aug 29, 2011 | 01:30 PM
bentryder's Avatar
bentryder
loud banging on start up...hard to find netural...noise in primary.....these are beginning symtoms....gets worse from here....there are alot of threads in here about it for more help....changed mine last week...about a 3-4 hour job....se compensator kit and primary gasket are about 280-300 bucks...
Old Aug 29, 2011 | 06:23 PM
speakerfritz's Avatar
speakerfritz
there are two SE comps. One has a version number of June 2010. difference is a plastic thrust washer on the newer one with spiral oil grooves.
Old Aug 29, 2011 | 06:56 PM
1fathog's Avatar
1fathog
Anyone have the part number for the latest SE Compensator listed above?
