Streetglide tail lights burning out
Old Aug 30, 2011 | 03:31 PM
mrfikser's Avatar
mrfikser
check the voltage regulator and the ground for it..it might be spikeing voltage if you rev. it real fast..
Old Aug 30, 2011 | 03:48 PM
Hickster's Avatar
Hickster
I am on my 5th (left) bulb on my '11 SG.I took it in and the dealer said everything checked out.They have given me 4 free bulbs,but this is a pain in the *** and I don't want a ticket.These LED bulbs y'all are talking about,are they a definite fix? Do you simply change to the LED bulbs? How much do they cost over the regular bulbs? Any help much appreciated.
Old Aug 30, 2011 | 04:06 PM
qtrracer's Avatar
qtrracer
There are Led bulbs out there but there are regular bulbs with the LL designation that are supposed to be better in a higher vibration environment. Check into it and see if they will help you and use DE grease when installing to help eliminate poor connections in the socket.
Old Aug 31, 2011 | 01:17 PM
journeyman's Avatar
journeyman
Guys, Just to update;
The dealer got info back from the factory techs on this issue.
They acknowledged 2011-2012 Streetglides are known to blow bulbs often and credited it to vibration. They said they suppliers of the bulbs, sockets, and wiring have not changed. Only Streetglides are affected of those years. They recommend replacing bulb to LED style.
Those 1157 LED bulbs range from $10 - $50. My dealer offered install the $10 ones foe free or to split cost of a better upgrade.
A link to what we will try below;
http://www.dragspecialties.com/part/...alties&partIds[]=107460
Old Aug 31, 2011 | 01:33 PM
KYFATBOB's Avatar
KYFATBOB
Have had my 2012 SG for 3 weeks and the right bulb already went bad.... Still had turn signal and brake lights but that was it.
Old Aug 31, 2011 | 02:54 PM
hoethree's Avatar
hoethree
I have a 2010 StreetGlide. Dealer set me up with red bulbs with red lenses on the rear. One of the bulbs burned out while riding to Sturgis in 2010. Went to three different Harley dealers on the way looking for a replacement bulb. Everyone of them (3) looked at the bulb like they had never seen one before. I wound up going to AutoZone and bought a LED bulb for about $20 for the pair. They worked and got me home but were not very bright when brakes applied. I bit the bullet and went to CustomDynamics for a full LED kit with load balancer. 48 LEDS in each light! They ARE BRIGHT and I am very happy with them. Not happy about spending $200 bucks though.
Old Aug 31, 2011 | 03:18 PM
iclick's Avatar
iclick
Originally Posted by journeyman
The dealer got info back from the factory techs on this issue. They acknowledged 2011-2012 Streetglides are known to blow bulbs often and credited it to vibration. They said they suppliers of the bulbs, sockets, and wiring have not changed. Only Streetglides are affected of those years. They recommend replacing bulb to LED style.
HD's explanation doesn't make sense to me. The '10 SG used the same bullet lights in the rear and '06-'09 are essentially the same with an added center section that shouldn't affect the their integrity. So why all of a sudden do the '11 and '12 models break bulbs? Do these vibrate any more than my '07, or for that matter a '10 model? So far Hoethree is the only '10-model owner who's reported a problem, and I think his was using a non-stock (red) bulb.
Old Sep 1, 2011 | 09:26 AM
journeyman's Avatar
journeyman
Not to defend the MoCo (really not happy with their argue-for-warranty-service policy, to put it nicely) but that is what they said. Just passing on the message here.
To help make sense of it, some history. I traded in my 09 Streetglide with over 17k miles, with the same bulbs the factory installed, for a 2011 Streetglide that can't hold a bulb for a month. You would think those bikes are nearly identical, the 09 had a 96cu, the 2011 has a 103cu, perhaps the motor contributes, but the taillight is very different. The big center light was removed in 2011 and maybe it resonates vibration just a little more. That center light might just have been enough of a vibration dampener to make the difference, same thinking could go for the tour packs on the Ultras, as they are not seeing this problem either. Just guessing on why.
I have now heard numerous identical problems.
One thing is for sure, there is a problem with 2011 -2012 Street glide tail lights and MoCo has Acknowledged it, at least to me.
Old Sep 1, 2011 | 07:01 PM
Hickster's Avatar
Hickster
Are those 1157 LED bulbs a Harley-Davidson part/part number? Do you just simply change them out? If this is a fix I will go pick some up this weekend.Any mention of a recall?
Old Sep 1, 2011 | 09:03 PM
iclick's Avatar
iclick
I believe you and wasn't questioning your statement at all. I just don't understand the Moco's reasoning.
To help make sense of it, some history. I traded in my 09 Streetglide with over 17k miles, with the same bulbs the factory installed, for a 2011 Streetglide that can't hold a bulb for a month. You would think those bikes are nearly identical, the 09 had a 96cu, the 2011 has a 103cu, perhaps the motor contributes, but the taillight is very different. The big center light was removed in 2011 and maybe it resonates vibration just a little more. That center light might just have been enough of a vibration dampener to make the difference....
In an earlier reply I mentioned a possible difference in integrity created by the absence of a center light, but I don't recall hearing about 2010 models having this problem and AFAIK their tail lights are the same as '11 and '12 models. HD implied the design and vendors had not changed.
...same thinking could go for the tour packs on the Ultras, as they are not seeing this problem either. Just guessing on why. I have now heard numerous identical problems.
Yes, and here's a thread where at least a few late-model Ultra owners are having the same problem with Tour Pak bulbs. It makes you wonder if the problem doesn't lie somewhere else, like the TSM/TSSM. OTOH if that were the case you'd think Ultras and others with conventional turn-signals would be blowing turn-signal bulbs prematurely as well.
There's a problem, for sure, but if vibration was the cause why wouldn't you see such problems on the old solid-mount bikes like older Softails and Sportsters? There was much more vibration in that environment than in current touring bikes, although it may be a factor or the quality of the vibration rather than the quantity--i.e., a specific frequency that knocks the bulb out quicker.
