ecm ?
Old Aug 30, 2011 | 11:05 PM
POPASICKBOY1's Avatar
POPASICKBOY1
Default ecm ?
If I do cams and a throttle body with a 95 inch kit I know I need to reprogram the ecm, do I need to put it on a dyno or can one of them fuel paks do the trick tuning the bike?
Old Aug 30, 2011 | 11:23 PM
POPASICKBOY1
bump bump bump
Old Aug 30, 2011 | 11:29 PM
XARAN's Avatar
XARAN
Call jamie at Fuel Moto and get a Power Vision instead of the PC V , many more options and no piggy back tuner on the bike
Old Aug 31, 2011 | 06:26 AM
kojak's Avatar
kojak
Depends on what you use. If it was my bike, I would use a SERT type device and get it dyno'd.
Old Aug 31, 2011 | 08:44 AM
jjnoble's Avatar
jjnoble
I can't tell you which programable tuner to get, everyone has their own preference. I use the TTS. But I think you should get one you control and program so you can change it yourself whenever you want vs one someone else puts a map into and if you want it changed you have to pay them to do it again.
Old Aug 31, 2011 | 09:08 AM
fabrik8r's Avatar
fabrik8r
Changing cams you will need a tune if you want to achieve a specific tune condition, how you get there is up to you; reflash, piggy back, Dyno, autotune. It really depends on what you are trying to achieve or what you are willing to accept. Just curious what your build plan is that requires a throttle body for a 95".
Old Aug 31, 2011 | 10:01 PM
POPASICKBOY1
its off a SE bike, it is better than the stock on on my 88ci
Old Sep 1, 2011 | 07:32 AM
fabrik8r's Avatar
fabrik8r
Sorry I don't know if the throttle body off a SE bike is larher, it might be if its off a 110" SE motor.
Old Sep 1, 2011 | 09:17 AM
POPASICKBOY1
It is 50mm and went are you so against changing the throttle body and injectors?
Old Sep 1, 2011 | 09:54 AM
fabrik8r's Avatar
fabrik8r
I'm not necessarily against using a larger throttle body, but it may not be necessary to use a larger throttle body, and it may actually have a negative effect on performance. Unless you are doing a fairly radical 95" build, high lift cam and oversize valves, a larger throttle body will not compliment your build plan. Higher intake velocity makes more power, bolt on a larger throttle body and you lose velocity. If you are going radical, then by all means use the larger throttle body, but if your doing a mild build with a bolt in cam, and maybe light port work on the heads, I wouldn't use a larger throttle body.
