ecm ?
Old Sep 1, 2011 | 10:04 AM
XARAN's Avatar
XARAN
Originally Posted by fabrik8r
I'm not necessarily against using a larger throttle body, but it may not be necessary to use a larger throttle body, and it may actually have a negative effect on performance. Unless you are doing a fairly radical 95" build, high lift cam and oversize valves, a larger throttle body will not compliment your build plan. Higher intake velocity makes more power, bolt on a larger throttle body and you lose velocity. If you are going radical, then by all means use the larger throttle body, but if your doing a mild build with a bolt in cam, and maybe light port work on the heads, I wouldn't use a larger throttle body.
+1, with a mild to mid rage 95 build that is going to remain streetable you could use the $ for other things than a Throttle Body, it wont improve your performance. The stock Throttle Body will easily support a Stage 2 - 95 kit (ac, exhaust, cams) or a Stage 3 - 95 kit (ac, pipes, cams, head work)
Old Sep 1, 2011 | 10:40 AM
POPASICKBOY1's Avatar
POPASICKBOY1
Why is it stock on a 95ci SE MOTOR? I MEAN if a negative result?
Old Sep 1, 2011 | 02:05 PM
fabrik8r's Avatar
fabrik8r
I don't know the specs for the 95" SE motor your parts are coming from, and I'm not about to speculate what the blue print looks like. If you keep asking, someone will chime in and give you the answer you're fishing for and permission to use the 50mm TB. I over cammed and over ported the first motor I ever built, it was an expensive and frustrating lesson, I guess you will have to learn the hard way also. Good luck.
Old Sep 1, 2011 | 03:10 PM
XARAN's Avatar
XARAN
It may not produce a negative result, IMO its just not needed to get the performance out of a basic 95 Stage 2 or 3 motor. There could be better ways to spend your $.
If you have not built a HD motor its really important to have a soild plan before starting or you may waste a lot of $ on do overs or not get good results by combining the wrong cams, pipes, heads etc
Old Sep 1, 2011 | 07:08 PM
POPASICKBOY1
Xaran, I would love some input on some good proven mods for my TC 88 on a touring bike if you have done some. I have Thunder Heads with true dual headpipes and a spare set of jugs and heads ready to go.
Old Sep 1, 2011 | 07:29 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
head work can change everything,the rest of the build should be designed to compliment the head work and commpression.the whole package has to work together,u can get very good results using relativly mild parts.
chamokie
Aug 11, 2017 09:41 AM
4srco2
Exhaust System Topics
Apr 17, 2012 12:22 AM
POPASICKBOY1
Aug 31, 2011 11:41 AM
Cav Cop
Nov 12, 2009 09:10 AM
brien
Nov 22, 2007 06:41 PM
