Charging problem
Old Sep 1, 2011 | 10:19 PM
chasityrick's Avatar
chasityrick
1st Gear
Default Charging problem
I have a 06 Ultra Classic. The voltage gage drops 14VDC to 10 VDC and the battery and check engine light comes on. This may last for several miles and then it returns to 14 VDC and the check engine and battery lights go off. This will happen several times in a 50 mile distance. What would cause this and what would be some things I could check.
Old Sep 1, 2011 | 10:47 PM
mkguitar's Avatar
mkguitar
It sounds as if you might have an accessory which is drawing too much power, then a breaker blows and the volts come up...then the breaker cools and resets... and the voltage reads low again.
(do you have anything added or changed to the stock wiring?)
but first you have to check that you are getting proper voltage at the battery with a "real" meter ( because the one in the dash is not the best and if you had corrosion on the wires to the gauge, it would maybe read wacky
so voltmeter on battery, motor off it should read 12 volt-ish, start bike, rev up over 3000 rpm and you should see about 14.5 volts.
if you have readings that differ greatly from that you have a charging system concern.
check those first.
it may also be a good idea to pull the battery, charge overnight on a "real" charger if you have one ( not a tender or trickle charger)- take to autozone and load test...
possible the battery is loosing a cell, which would put a great strain on the charging system- causing further damage.
couple of checks, let us know how you do.
mike
Old Sep 1, 2011 | 11:11 PM
Jackie Paper's Avatar
Jackie Paper
First thing I would do is make sure your battery terminals are tight. My bet is something is loose
Old Sep 1, 2011 | 11:25 PM
dbell66253's Avatar
dbell66253
My bike did the exact same thing when the stator was on its way out, after awhile it stopped charging.
Old Sep 1, 2011 | 11:31 PM
Dustball's Avatar
Dustball
All good recommendations above. Check battery terminals and wires for corrosion, and be sure to check your regulator grounding too.
-Dusty
Roni
Aug 5, 2024 05:13 AM
spalmer1214
May 22, 2021 03:34 PM
WOLFE1584
Mar 11, 2013 05:57 PM
51Moe
Aug 16, 2010 08:07 PM
d59s67
Jun 23, 2007 10:51 AM
