Xieds ???
Old Sep 2, 2011 | 07:58 AM
pauletich's Avatar
pauletich
Default Xieds ???
Can someone explain xieds to me. I have seen this posted a lot, but can someone let me know what it is and what it does?
Old Sep 2, 2011 | 08:17 AM
JayStronghawk's Avatar
JayStronghawk
Simply put is a Variable Resistor in Line with your O2 Sensors that Fool your ECM into making your AFR Mixture Richer thereby running cooler .. Fancy Jumper Wires if want totally simple ..
Old Sep 2, 2011 | 08:21 AM
vtwinbob's Avatar
vtwinbob
here's a good read and and a good place to start to your question about XIEDS http://www.nightrider.com/parts/
Old Sep 2, 2011 | 08:32 AM
pauletich's Avatar
pauletich
I have a 07 FLHX with stage 1, V&H monster ovals and a V&H fuel pak. Would this still work for me? I still run pretty hot with the code I have for the fuel pak.
Old Sep 2, 2011 | 08:34 AM
Ronp42's Avatar
Ronp42
Account Retired
I've been running them for two years now on three different bikes. I have them on the 2012 Triglide you see in my sig pic. Go to tuneyourharley.com
Lot's of good reading there. Lot of good info on how capable the stock ECM is also. As long as you stay with the stock headpipe, cat or no cat and stage 1 Air filter and slipon's, the xied's will work fine IMO.
Old Sep 2, 2011 | 09:09 AM
hoethree's Avatar
hoethree
I put them on my stock 2010 StreetGlide. Honestly couldnt tell you if they "work" or not. Still running them assuming the engine is "cooler" but have no idea. Its always hot when I touch it!
Old Sep 2, 2011 | 09:19 AM
roadglide sy's Avatar
roadglide sy
Default xeids
check out the websit shown in an above post and maybe call them and they will say if they will help with your set-up I hear they are very easy to talk to and helpful. Thanks Jim
also wont help cool engine down to touch ,but will richen up fuel mixture to help cool down exhaust....
Old Sep 2, 2011 | 09:20 AM
Willie D's Avatar
Willie D
Wink Xied
They work !
I have the older 02 IED's on my 2010 FLSTFB, with the Bassani Road Rage Long w/Quiet B. stock AC No stage 1 download, and yes it is still Hot, but not as bad as it was with the stock exhaust w/cat.
AFR is 14.2
JMHO
Call the nightrider guys and they will give you the straight talk about how/why they work.
Old Sep 2, 2011 | 10:04 AM
aviaator's Avatar
aviaator
+1. I have 'em on my 2011 FLTRU and honestly can't tell a difference with the "butt dyno." Engine heat seems the same too. I'm keeping them on for peace of mind (placebo effect?). I don't like how lean the stock ECU runs so I'm hoping this richer mixture helps prolong my engine's life.
Old Sep 2, 2011 | 10:13 AM
mkguitar's Avatar
mkguitar
I have some ASE training.
My 09 when stock had a slight pinging problem under certain riding conditions which was repeatable.
XIEDS solved that, making the mixture slightly richer.
With that, I was able to add hi flow exhaust and intake and retain good function.
they are a simple solution to a sometime complex problem
MPG maybe dropped from 44 to 43, they cost about $125 shipped, and they offer a Military Discount ( which my Bro got)
mike
