How many miles?
Old Sep 2, 2011 | 04:10 PM
Tooth's Avatar
Tooth
Default How many miles?
any big mileage riders out there?
basically looking to see how many miles you guys are putting on your bikes and who is still running strong with out engine issues.
Old Sep 2, 2011 | 04:47 PM
'05Train's Avatar
'05Train
2010 FLHTK, bought new 11/22/2009, just shy of 42,000 miles.
Replaced or repaired under warranty:
- 7 tires (ESP)
- 2 wheels (chrome flaking)
- H-K stereo
- compensator (replaced with S/E)
- clutch (replaced with S/E)
- rear pulley
- whole top end of of engine "worked loose"
And it'll be going back in soon for a leaking stator plug.
Old Sep 2, 2011 | 05:13 PM
Bodean46's Avatar
Bodean46
01 Ultra bought Nov. 07 with 4995 miles. Just rolled 40000 and other than a lifter going bad at 13000 no other problems. Added gear drive cams when replacing lifters and only other issue was a PCIII taking out ECM fuse.
Old Sep 2, 2011 | 05:26 PM
DTTJGlide's Avatar
DTTJGlide
2000 with 104K, 82K on a built 103, P&P heads, Crane 570 lift cam & springs, 10.2 comp, replaced the head gaskets a couple of years ago because of oil seapage & went with hyd tensioners at 68K on the engine, otherwise no problems & I average about 42-45 mpg with MM FI.
Old Sep 2, 2011 | 05:29 PM
tonsa's Avatar
tonsa
- 7 tires (ESP)
- H-K stereo
- rear pulley
You must have driven all over the states. You should apply for iron butt. You retired? or rich? congrats to lots of miles. Enjoy many more.
Old Sep 2, 2011 | 05:54 PM
santajim's Avatar
santajim
'09 FLHTCU just turned 40,000 miles and no problems.U
Old Sep 2, 2011 | 06:14 PM
kentuckyarms's Avatar
kentuckyarms
08 FLHTC bought new in spring of 08. 52,800. No engine problems.
Old Sep 2, 2011 | 06:20 PM
vistavette's Avatar
vistavette
I'm not nearly as high up as these guys; but I took delivery of my '09 Ultra in July of '09 and have about 27k on her; not one issue. No real mods though; just slip ons/stage one DL and AC
Old Sep 2, 2011 | 06:22 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I ride 30k-40K a year.
4 TC's and one Sporty in last 12 years.
A few minor issues with each one, except a TC88 on a 05 RK that grenaded at 50K miles due to an out of round crank.
Engine was re-manufactured under extended warranty for $50.
Kevin
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Sep 2, 2011 | 06:28 PM
Stiggy's Avatar
Stiggy
'00 FLTRSEI
New to me Auqust 2007 at 23,900 miles. Just turned 93,000 miles last week.
After 2 stator failures, replaced charging system with Compu Fire 3 Phase and no more problems with stators.
At 67,000 miles, drove home from Myrtle Beach with a small crack in the Y Pipe. (didn't know it.) Next morning hung an exhaust valve on startup which tapped the piston. Replaced both heads with clean take offs and got a new exhaust.
81,000 New Gear Drive cams.
Nothing to complain about, my Daily Rider.
