PCV Recommendations
Old Sep 9, 2011 | 01:29 PM
bigmick23's Avatar
bigmick23
Default PCV Recommendations
Hey gang,
Looking for some recommendations. I recently installed a PCV on my 09 Street Glide when I installed the exhaust and did the 103 upgrade. I've yet to have it dyno'd so it can be tuned perfectly. Hoping that will rid my "hot start" issues. Anyhow, will adding the dynojet autotune help? I've heard mixed emotions on it. Any info would be greatly appreciated! Thanks!!
Old Sep 9, 2011 | 05:15 PM
Phat09flhx's Avatar
Phat09flhx
Installed cams and had the same problem with my stock 96" and decided on the autotune, the only thing I didn't know is the autotune won't work unless you go out and do some 100% throttle runs. I went from the bike acting stupid and shutting the cylinder down and getting maybe 32 mpg to over 38 and the bike idles with the potato lope that everyone looks for. Been smiling since
Old Sep 9, 2011 | 05:29 PM
JRBass's Avatar
JRBass
If you bought your PCV from fuelmoto why don't you just call them and get a map for your setup. I am sure they have one. Even if you didn't buy it from them I would call hin anyways... If he charges a couple bucks for it, it would be worth it. Most of there maps are pretty spot on.
Old Sep 10, 2011 | 09:25 AM
bigmick23's Avatar
bigmick23
Thanks for the info guys. I spoke with a dynojet rep this weekend at a rally. He said he strongly recommends the autotune with a dyno to complete the setup. He said about only 40% of the maps that you can download yourself are very accurate. Although the components of the map fit, every bike is still a little bit different. So I think I may just go that route.....
jlasoftail
Apr 5, 2017 06:40 PM
jlasoftail
Apr 10, 2012 06:45 PM
JackieGrier007
Mar 7, 2010 09:04 AM
jeff.georgalas
13
Oct 17, 2009 09:19 PM
09StreetGlider
Jan 27, 2009 10:04 PM
