Why can't I win????
I was wondering if 150 was low or not. I did the compression check cold and got 149-150 on both cylinders for 3 tests each. The heads are stock, bore is 95, cams are 26N's we are at 600 ft above sea level in Illinois.
Hope this helps- if the rings were bad, causing lost compression, or if the gasket has went bad, causing low compression wouldn't I hear that in the leak down test? I couldn't hear any air leaking anywhere and gauge took about 2 min to even move down 5 points.
I have not negated the possibility that they simply push harder than I do, or ride better than I do. I'm not a jackwagon out street racing, if you're trying to sell the line of BS that says you never grab a handful of throttle and go either with or without your buddies around, I would tell you I ain't buying it!
I've said at least twice in this thread, that regardless of whether or not I was trying to out perform my buddies bike, mine just doesn't have the performance gains I would expect with the set up I have. I expected the cams to be from around 1800-5000 ish ( this is what I expected the TQ part to be very fast at), what I feel is a sharp drop off in power around 4ooo-4500, from there I would expect the HP to kick in and continue to build speed not fall on it's face.
I was able to get the leak down and compression test done late last night, both cylinders reported 150 on compression and < 5% leak down i.e. the gauge didn't hardly move for several minutes. So this tells me that cylinders, rings, and valves are in good shape. This confirms what we saw when we did the head gasket this past spring.
I have not looked at the gearing yet I hope to do that this week.
Maybe something else I need to look at is how hard I run it. Would someone be willing to walk me through their typical shift sequence in this situation? I know lugging my bike it bad news, but does taking it to red line hurt?
Thanks for the replies
Now about the BB calculator:
not real sure what I need to do there to get the compression ratio to be correct. I played with the head CC number until the corrected compression number matched 150, that tells me that my static compression is 8.32.1 and corrected is 7.82.1 ( I had to input 95 cc head value for this) Does this sound right????
Thanks for the information. What youre saying makes sense to me at this point. Guess, I will just drive it until the snow starts falling and then tear into it. I'm still finding the best places for parts so would you care to share where you are getting cylinders at that price from, and then any idea the best place to get pistons if I go that route?
Here is what I posted back in #25.
One thing that isn't adding up is that the '99 EFI bikes came with 3.37 final drives; you should have that going for you. I would pull the chain case cover and verify the tooth count on the sprockets and the tooth count on the trans and wheel pulleys. I know 88" bikes with 3.37 gearing and mild cams that will spank a Stage I 96"er.
Yes, you should be thinking about head work and more cam (TW37) to go along with the headwork and more compression; a simple BigBoyz street port would make a big difference. A 2:1 pipe would help but the duals are not your problem and Fullsac makes a good system.
Get the compression and leak down test done, post the results and there is enough help on this forum to put you back in the hunt with your two riding buddies.
I would not go to 98" as that would require a set of forged pistons; I like to stay with cast if possible. So, get a set of .010" OS H-D 10.25:1 cast hi-compression pistons, cylinders bored to fit, heads worked ala BigBoyz or Short Block Charlie, (larger intake, basic velocity street port chambers cc'd and balanced, bronze guides, manual compression releases and multi angle valve job), .030" head gasket and install TW37 cams. Now you are looking at 10.14 static, CCR of 192 and corrected CR of 9.39 and show your buddies some tailights. 9.3 is a good target for corrected CR on a street build and 192psi is manageable without compression releases but I would install them anyway just to extend battery and starter life.
I would not bother with decking the heads and using flat top pistons to get the additional compression. JMHO, but achieving the desired compression with a domed piston is a better way to get there. If you have the money and desire to upgade the cam plate/tensioner system the the SE Hybrid system that would be a good idea and an ideal time for the upgrade. However, if you don't want to spend the $$, replace the tensioners, the inner and outer cam bearings and install the Baisley LMR-002 oil pressure relief valve spring.
Get a fuel management system and get her tuned by somebody familiar with MM EFI; those are a bit more challenging than the Delphi system. Get a break in tune, get about 1000 miles on the motor and back for a full tune and then line up with your buddies; it will be different race. Oh yeah, take the advice on how to ride when racing.
As always, JMHO and everybody has one.
