Why can't I win????
Old Sep 12, 2011 | 04:38 PM
  #41
lh4x4's Avatar
lh4x4
coolerman69. Okay your on.
Which of these do you think you can beat?
By the way they all have much more HP than you signature states for yours and far less weight.
Old Sep 12, 2011 | 05:38 PM
  #42
coolerman69's Avatar
coolerman69
Read the post again. Sig bike is my daily driver. I'm referring to my 05EG sleeper. VROD stock- not a chance in 1/8 or 1/4. Top end i loose. Sportster loses all around. If thats a 1200 buell.....I probably lose!
Old Sep 12, 2011 | 05:52 PM
  #43
soft 02's Avatar
soft 02
And on the next episode of Pinks........
Old Sep 12, 2011 | 05:53 PM
  #44
terryrh's Avatar
terryrh
I like you Larry. I'm not even BS'n I wanna live my life like you do when I get a bit older.
Old Sep 12, 2011 | 06:15 PM
  #45
$tonecold's Avatar
$tonecold
I will try to get the compression and leak down test done in the next day or two. I'm pretty certain it will come back within tolerance as we just had the heads off in the spring to do the gaskets, and the cylinders looked great as well as the valves had no leakage, etc. I will start there and see what the numbers show. I will post them up once I have them maybe from there we can start to narrow it down.
If you get a Cold Cranking Compression check, you can go to www.bigboyzheadporting.com and using their twincam calculator figure your static and dynamic compression. Don't forget about altitude, it makes a difference on dynamic compression. In other words, you will make the dynamic compression match your CCC reading and work backwards to figure your static compression.
Old Sep 12, 2011 | 06:22 PM
  #46
hd1450's Avatar
hd1450
Talking
They put back pressure in those stock pipes for a reason. Most bikes running straights run like **** unless their tuned for high rpm racing. Sounds like you need a good tuner and drop that sucker down a gear or two @ 60mph. 4th gear @ that speed for racing is just wrong.
I used to smoke 96's all the time with a 50K+ mile 88B just by the way I ran thru the gears.
Is your tuner 'sniffin' each pipe individually? Switching sprockets suck in the lower gears if your just cruisin most of the time.
When is the last time you really ran thru those gears and ran the twisties using the engine for most of your braking? You''ll find out real quick what that engine is capable of. My quess is alot more than your running it. Engines need a good spankin some times.
  #47
anickel's Avatar
anickel
I think you need a tune. Canned maps are fine for getting you going but a tune is the way to go. I have basically the same build but still at 88", Fuel Moto gave me a map and bike was strong at low end but lacked at upper end, tried another map from dynojet which was pretty much the same. Got the bike tuned and it was a new bike, and the map wasnt far off.
Old Sep 12, 2011 | 06:30 PM
  #48
hd1450's Avatar
hd1450
Now thats some funny ****!!!
Old Sep 12, 2011 | 09:49 PM
  #49
coolerman69
LOL Nah i wouldn't take his scoot. but i would take his money!
Old Sep 12, 2011 | 10:25 PM
  #50
coolerman69
1/4et 1/4mph 1/8et 1/8mph 0-60et
11.479 119.290 7.290 97.390 1.690
These are without the bottle.
