Why can't I win????
Old Sep 11, 2011 | 05:30 PM
  #31
coolerman69's Avatar
coolerman69
Originally Posted by Jim Dawson
That is truly hard to believe.
Line um up and bring your title.......SIGNED! I can back it up.
Old Sep 11, 2011 | 05:31 PM
  #32
coolerman69
Originally Posted by terryrh
It's possible...if he has FI
I got it!
Old Sep 11, 2011 | 05:42 PM
  #33
coolerman69
Oh yeah, forgot to mention. 03 CBR600 doesnt want any out to about 500 ft. He spouted off about how slow Harleys were so i offered to race light pole to light pole. Thats 330ft. Standin start i smoked him to 330 and was thinkin i had him to 660 but when he went past it was like i was in neutral! If I can get it to hook up its pretty impressive.
Old Sep 11, 2011 | 05:50 PM
  #34
CndUltra95's Avatar
CndUltra95
My 02 Ultra is a big heavy bike obviously...(95inch 203 cams and dyno tuned)
My buddy who has 96 Road King with air filter and is stock as far as we know.
We did a side by side roll on in second gear from 25 MPH and walked away from me for two maybe three bike lengths , it didnt take long for me to run him down either.
He was in fourth gear and I was in third gear when I roared past him at 65 MPH or there abouts, hit fourth and left him behind.
Not a great drag race by any means, more of a test the two bikes old teck and new teck and that was about it.
If I wanted a drag bike I would go japaneas and get a zxr11 or a hyabusa something or other, anyways, sounds like you need to fine tuning on a dyno.
Rob
Old Sep 11, 2011 | 06:34 PM
  #35
18BKLR's Avatar
18BKLR
Originally Posted by Sputter
Smitty-
What do you mean? The parts are all brand new and in full functioning condition, or are you meaning the parts as a whole group not working together? I went with the Andrews 26 at the recommendation of several riders/builders for my type of riding ( mostly 2 up cruising) maybe it wasn't the right choice, but I can say the SE 206's aren't either as they were in the bike and it was worse than it is now in the upper RPM's
Just has me stumped
You just said it here. You did what you did for 2 up cruising and those are the recommendations that you got. Go tell the same people that you want drag racing power and I am sure they will give you a different cam to run. I agree with most. bump the compression some and that should wake it up.
Old Sep 11, 2011 | 06:44 PM
  #36
djl's Avatar
djl
Sputter,
Go back and read #25; follow the advice and work your way out. You should be staying with or pulling those guys with your build. With 3.37 gearing, you should be out in front from the jump; something ain't right.
I suggested headwork and if you go that route, the 26, though a nice cam, won't be enough cam to take full advantage of the upgraded heads.
Start with compression and leak down testing and verifying primary and secondary gearing; let's go from there.
I wouldn't ditch the Fullsac system just yet; let's get the basic stuff sorted out first.
Old Sep 11, 2011 | 06:49 PM
  #37
7125's Avatar
7125
Thumbs up
well you could have all the hp in the world most of the time its the drive
clearer head goes faster and done care
Old Sep 11, 2011 | 07:14 PM
  #38
JDB's Avatar
JDB
Default Fastest Harley
Isn't that like being the tallest little person!
Old Sep 11, 2011 | 09:08 PM
  #39
Sputter's Avatar
Sputter
I will try to get the compression and leak down test done in the next day or two. I'm pretty certain it will come back within tolerance as we just had the heads off in the spring to do the gaskets, and the cylinders looked great as well as the valves had no leakage, etc. I will start there and see what the numbers show. I will post them up once I have them maybe from there we can start to narrow it down.
thanks for all the replies I appreciate it!!!
Old Sep 12, 2011 | 06:45 AM
  #40
coolerman69
You said you had TDs but i didnt see what kind of slip-ons you have.
