Front wheel allignment Question - brake drag
Old Sep 18, 2011 | 07:30 PM
steelerdude1's Avatar
steelerdude1
Default Front wheel allignment Question - brake drag
Since I pulled my wheels for a tire change, my front brakes are dragging a lot more then they used to. When re installing the front wheel, I followed the Service manual's instructions.
2 things: I did not have a 7/16 drill bit, so I used a 7/16 allen key to align the right fork. I did this with the wheel on the ground.
Could using the allen key have put me out of alignment? should the front wheel be lifted up with no weight on it or down on the ground with the weight of the bike fully on it when aligning it? or doesn't that matter?
Old Sep 18, 2011 | 07:37 PM
hojones's Avatar
hojones
I dont use the drillbit at all. I let the fork go against the spacer and torque the axle nut, then torque the pinch nuts. Never had a problem doing it that way.
Old Sep 18, 2011 | 11:15 PM
steelerdude1
Any one know if the alignment should be done on the ground or on the jack? I'm going to start from scratch tomorrow, and re install everything.
Old Sep 18, 2011 | 11:29 PM
turbotony's Avatar
turbotony
on the jack....imo
Old Sep 19, 2011 | 05:32 AM
Olde Skool's Avatar
Olde Skool
Clean the calipers if you didn't do it the first time...
http://www.lyndallracingbrakes.com/service_tech.htm
Old Sep 19, 2011 | 10:21 AM
Ultrathunder's Avatar
Ultrathunder
On 08 and up Bikes (Bembo Brakes) do NOT use the drill bit , To fix it, lift the bike up off the ground loosen up the fork caps let the forks and axle line it self. Trust me I had to replace a Rotor because of it.
Old Sep 20, 2011 | 03:23 PM
steelerdude1
I realigned everything today, This time on the jack. I bought a 7/16 drill bit, and with it off the ground, it was lined up, did not have to pull the fork. While I was at it, I pulled my brakes and sprayed my calipers really good with brake clean. Wheel spins like normal now.
Dizzy810
Nov 8, 2013 02:09 PM
jsfinco
Wheels/Tires
Jun 25, 2009 09:17 AM
ctmedic
Apr 28, 2008 05:49 PM
03RKC
Apr 5, 2007 09:01 PM
tattooedskin
Ironhead
Jul 9, 2006 04:02 PM
