Fairing insert t-r-o-u-b-l-e
Old Sep 20, 2011 | 07:16 AM
gobblerhuntr's Avatar
gobblerhuntr
Default Fairing insert t-r-o-u-b-l-e
On a recent road trip I had to JB Weld one of my top fairing inserts back into the inner fairing and did not get it pushed back far enough in the inner to get a good grip on the windshield/outer fairing. Wondering if anyone had any ideas on how to get the insert out (break the JB Weld loose) and reinsert it at the proper depth to hold the outer properly?
Old Sep 20, 2011 | 07:23 AM
coolerman69's Avatar
coolerman69
Your probably not gonna break the jb weld loose without breaking the faring. You might try trimming off the insert to make it flush. Good luck!
Old Sep 20, 2011 | 07:48 AM
Chunker's Avatar
Chunker
Maybe with a high speed drill cut away from the JB weld to weaken the bond. Not sure if a drimel type tool would have an attachment that could drill,cut/grind away at the bonding material to gently break it free. Sort of like a dentist cleaning up around a cavity.
Old Sep 20, 2011 | 08:03 AM
santajim's Avatar
santajim
And then when you get the old one out go to the dealer and get the repair inserts they thread in and hold good. Ask me how I know.
Old Sep 20, 2011 | 08:33 AM
chidiver's Avatar
chidiver
$1.70 as of 2 days ago.
Old Sep 20, 2011 | 09:13 AM
xpilot's Avatar
xpilot
You may want to try heat. The heat will soften the epoxy enough to remove the insert. Find a longer bolt that fits in the insert. Grab it with a vice grip, and lay the torch to it till it glows. Thread it into the insert and start a slow tug. You may need to heat it again to transfer enough heat to the epoxy.
Good luck
Old Sep 20, 2011 | 09:14 AM
kdichs1015's Avatar
kdichs1015
The insert would be soft enough that you could easily file off the protruding part, after removing the outer fairing.
If you really want to remove the insert, I would drill it out, using progressively bigger bits, and the drill at low speed.
Maple Leaf Hog
May 2, 2008 03:52 PM
Gregte
Jul 1, 2007 01:16 PM
rlb5857
Apr 19, 2007 11:24 AM
ricaroo
Apr 17, 2007 11:50 AM
jdag
May 10, 2006 05:55 PM
