Need some help.. Snapped front axle holder bolt.
Old Sep 22, 2011 | 05:46 PM
Woodbury's Avatar
Woodbury
5th Gear
Default Need some help.. Snapped front axle holder bolt.
Putting my new tires on. Tightened my front axle holder nut too much, SNAPPED it. 2007 Road king standard. The bolt comes out of the bottom of the fork . Anybody had to deal with this? Thanks for any info.............
Old Sep 22, 2011 | 05:56 PM
buggy's Avatar
buggy
If it screwed out ,you can get a new one .
Old Sep 22, 2011 | 05:57 PM
dawg's Avatar
dawg
And if it didn't screw out, then screw it out and get a new one.
dawg's Avatar
dawg
BTW, the torque spec on those two are in INCH pounds.
Old Sep 22, 2011 | 06:00 PM
dyebartdie's Avatar
dyebartdie
Use a little heat and some vise grips and it will come out.
Matt0987's Avatar
Matt0987
If it snapped off with the bolt sticking out of the hole, yes, vice grips. Perhaps a little heat. Unless you used a thread lock. Then, I do not know, but then you may make things worse by cooking the chemical. Others will have to chime in about this aspect.
Assuming it snapped off with the bolt recessed inside of the hole....
Time for an "easy out".
Sears has a couple of sets;
http://www.sears.com/shc/s/search_10...yword=Easy+Out
I happen to like this type;
http://www.sears.com/shc/s/p_10153_1...1&blockType=G1
Regardless of which type you use the real key to success is to set your disappointment and frustration aside, take your time, follow the instructions.
When you drill the initial hole use a "set", a center punch, to mark the center of the bolt that is in the threads. Then use a small, very small, drill bit - with a little oil - to drill the initial hole. Followed up by a drill bit a little larger than the last. Work your way up to the proper size hole for the extracting tool.
Just take your time. If you get discouraged walk away for awhile. Over night if you have to.
It can be a tedious process but frustration will only make the process longer and filled with errors.
But, once you win, you will be very satisfied.
Old Sep 22, 2011 | 06:01 PM
6 gun's Avatar
6 gun
One center punch one electric drill
one small left hand drill bit one small
four cornered eazeout and a adjustable
wrench. Do not use the spiral twisty
kind of a eazeout. Then add a little luck
and presto, there you go.
Old Sep 22, 2011 | 06:12 PM
69cj's Avatar
69cj
If you don't have a shop manual, get one. If you do, read it.
Old Sep 22, 2011 | 07:27 PM
mrfikser's Avatar
mrfikser
sometimes you can mash the broken stud real hard against the part still left in the hole and turn the broken end out....if that doesn't work do the above....the bad news is you are probably going to have to remove the shock from the bike to get to the broken stud...
Old Sep 22, 2011 | 08:07 PM
Hoblick's Avatar
Hoblick
My buddy did the same thing. I tack welded a nut on the broken end and just turned it out with a wrench
