25mm vs 1 inch axle
Old Sep 23, 2011 | 11:45 AM
MBrown's Avatar
MBrown
Just by looking you can see The axle nut is different sizes on between the 2 axles.
Old Sep 23, 2011 | 12:02 PM
FastHarley's Avatar
FastHarley
Former Sponsor
use your old axle than buy the proper bearings and inner spacer for it. Cheaper than a new $78 axle. Good bearings cost around $12/each and the spacer is around $7.
Old Sep 23, 2011 | 03:02 PM
blockzilla's Avatar
blockzilla
if you use the 2010 bearings you must use the 2010 axle.. same with using the 2007 axle you must use the 2007 bearings ... or like I mentioned earlier .. take your 2010 wheel and 2007 axle to a machine shop and have them turn the axle to .983 in a lathe and it'll be a 2010 axle .....if you were close to me I would do it for you....and you wont have to rent the axle bearing puller or pay HD or an Indy to pull the bearings for you and press new in...
Old Sep 24, 2011 | 09:02 AM
smharris605's Avatar
smharris605
Thanks for all of your replies!!! And thanks for the offer blockzilla! I'm just gonna buy it and compare...
evomat
Feb 24, 2016 12:46 AM
Vt harleydyna2003
Sep 28, 2014 05:48 PM
Failz
Feb 25, 2010 08:57 PM
basstracker05
Feb 1, 2009 11:42 PM
gunnert
Wheels/Tires
Dec 22, 2008 04:32 PM
