I'm trying to buy a 25mm axle so I can put a 2010 wheel on my 07. I'm talking to a seller who thinks he has a 25mm but wants to make sure it is in fact a 25mm axle before selling it. Is there any way to tell the difference between the two aside from measuring? Thank you very much for your help!!
I would measure with a dial caliper. Its hard to see the .015 difference and having never looked at the 2 side by side, don't know if there are id marks on them.
i would measure with a dial caliper. Its hard to see the .015 difference and having never looked at the 2 side by side, don't know if there are id marks on them.
Either axle will work...I took a 2010 wheel and just made a direct swap. I think you might have to get the correct spacers to make the wheel fit correctly on a 2007. Someone please chime in if this is correct or not.
