Alternative Method of Venting the Crankcase
Old Oct 26, 2018 | 02:31 PM
Allen Green's Avatar
Allen Green
Stage II
Default Great way to do this no mess
buy a small high efficiency, like 1.5" x 1.5" 12vdc pump that can handle oil, (Amazon 15.00) Then connect to crankcase vent line and pump back into oil tank or connect to oil tank vent line. Oil tank is not a pressure vessel. Good Grief whoever said that.
make sure pump is on a keyed power wire.
ive had a 1991 FXRSSP for years.....this will fix it permanently, park it for winter even, excess oil will return to tank.
If yer nervous about oil going wrong way, don't, pump acts as it own check valve.
Alf ...FXRSSP......FLTRI with sidecar......FLHTC...'....64 Servicar Chopper w / the old TA radials and Cragars and 11" over girder springers.
Disability Scooter
"The HAMMER" Stroker and Ninja Killer Yes, used to be a Road SMASHED FXRS-SP Now s&s bank robber...."Broke Veteran" HA!!!
Old Oct 27, 2018 | 08:38 AM
btsom's Avatar
btsom
If I read the OP correctly, he wants to vent at the oil filler cap. In my humble, non engineering opinion, crank case pressure will vent through the easiest path. The umbrella valves will become irrelevant and the blow by and oil mist will vent out the cap moving the mess from the air filter to whatever is behind the oil fill cap. Harley, or an owner could just as easily connect the vent tubes to the intake manifold rather that to the air cleaner and change the circuit flow. That would eliminate the air filter mess but would still run the oil mist back into the engine with the associated deposit build up in the combustion chambers.
Old Oct 27, 2018 | 09:43 AM
hbsoldier3's Avatar
hbsoldier3
I would not want the crap that comes out of my external breather tube back in my crankcase.
Old Oct 27, 2018 | 01:25 PM
hdbob2006's Avatar
hdbob2006
The gunk that comes out of the breathers is about half WATER. You want to put water in your oil tank?
aces&8s
EVO
Oct 5, 2017 07:00 PM
buttman
Engine Mechanical Topics
Mar 5, 2014 08:11 AM
D'Rake
Dec 2, 2013 06:54 PM
hdpearson13
Ironhead
Dec 2, 2007 02:02 PM
NitroBerserker
Exhaust System Topics
Apr 22, 2007 06:39 AM
