Lowering Front End Only
Your words from the kit specs:
"The front end kit description in the catalog advises it only be used in conjunction with harleys rear end kit but the same advice is not in the description of the rear end lowering kit."
In essence you have made a non-authorised change to the suspension against the manufacturers advice.
I wouldn't now lower the rear to compensate, as you may have a poor ride depending on your weight, pax weight, and any added load you may carry. Just a suggestion.
http://www.dunlopmotorcycle.com/tire...ire.asp?id=111
Da Shadow, rather than put any more money or effort into the front end right now, add a set of 3-3 Ohlins to the rear; it will bring the geometry back to nearly stock, the ride will improve tremendously, and you get to keep the cool lowered look.
